Chris NottEM Tuning
    May 2008
    214
    Engine management light come on this morning
    Hi guys
    for no apparent reason this morning the engine management light come on
    since I've had the car it's been running fine
    however I've looked and noticed the airbox is broken from the bottom and has a major peice missing, but this has never caused a problem
    but maybe it's blocked the maf? Could that cause the light to come on?
    Cheers guys
    Oct 2008
    888
    not heard this one before. your air box? is it before the filter or after that is damaged. if its before then l wouldnt see that as a problem, whats the year of your motor,what model is it? is it still under warranty etc?
    May 2008
    214
    It's a 04 2.0 tdi s line
    I have since plug a diagnostics in, and it came up with a fault code saying coolent temp, I cleared it and the lights off,
    Just don't know why that came up? Lack of antifreeze?
