Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
    matzxr's Avatar
    47
    A3 3.2 Idle question
    Hello all ,
    my car has developed an annoying high idle fault when coming to a standstill , idles at approx 1100rpm for a minute or so then drops to the normal 800rpm .
    Any ideas ?
    Hellz's Avatar
    Geordie Racer
    Apr 2009
    Newcastle
    372
    On startup mine can idle at 1000-1100rpm for a short time before settling at 800rpm - I dont think it idles at 1000+rpm for a minute or so though...
    I think a slighty higher idle for a short time on startup is normal...
    AUDI S3 2007 Dolphin Grey
    PREVIOUS:
    AUDI A3
    3.2 V6 Quattro S-Line DSG
    AUDI S3 8L
    AUDI A3 1.8T Quattro
    8L
    edition's Avatar
    Nov 2007
    1,417
    From cold it revs at 1000-1100rpm then settles to about 700ish on mine.
    matzxr's Avatar
    47
    This isn't from start-up , it's when at normal running temperature , driving along then coming to a junction for instance .
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    only thing i can think of is possibly your thermostat isnt reading properly, and always thinking your engine is cold, but if this was the case, it then wouldn't drop back down to normal revs
    rs6's, H&R 35mm, lamin-x, vinyl wrapped grill, cupra splitter, black wing mirrors, de-badged, bmc air filter
    matzxr's Avatar
    47
    Anyone ?
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,199
    Sounds like you need a vagcom scan to see if there are any faulty sensors showing up. Have a look to see if there is anybody near to you on the locations list.
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    matzxr's Avatar
    47
    Cheers fella
    mark bo's Avatar
    Dec 2009
    hi there did you find out what was wrong with the idle problem ? mine also does this ,usaly when im stopped at traffic lights , very irritating any info would be great
