Chris NottEM Tuning
Thread: Oil
    ghouseman's Avatar
    Gazza
    harrogate
    92
    Oil
    anyone advise on the best oil for my a3 2.0 tdi 170 quattro,halfords told me castrol 5-40, but i have a feeling it should be 5-30, please help!
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I'm using 5w30 and that's the recommended one for 2.0tdi 140pd engine if that helps.
    VCDS USER
    ghouseman's Avatar
    Gazza
    harrogate
    92
    oil
    cheers,looks like halfords sold me the wrong one
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    never mind the viscoscity - it has to be VW approved. Even Castrol make three different 5W30s - one is VW approved, one Ford approved and one Mercedes.
    It also varies depending on whether you are on the fixed 12 month service interval or variable servicing.
    In a nutshell, if you go for VW507.00 approved spec fully synthetic 5w30, you will be OK, whatever service interval you are on.....
    But it has to have the VW 507.00 spec approval - as even the older VW506.01 spec is only OK for earlier cars without a particulate filter.
    So you need to make sure it says at least VW507.00 on it to be sure...
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    ghouseman's Avatar
    Gazza
    harrogate
    92
    cheers pal
