AH FabricationsSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
  1. #41
    david_phillips95's Avatar
    Nov 2008
    538
    Checked the sight glass on my catch can tonight and its about an 1/8th of the way up already, really amazed at how much crap has been caught in such a short space of time. ill post a pic up when i get a chance.
    Davie
  3. #42
    Fast,not furious's Avatar
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    [QUOTE=Forge;863955]The Forge catch can is designed specifically for the VAG engines , you will find that the internal baffleing works very well . we only supply the kits with Flourosilicon hoses as in time the oil will cause the hose to deteriorate
    have a look here to see what will come out of your catch can
    http://www.youtube.com/watch?v=QVRad3aPdVA
    ...and then it's sold on as 'coffee' in motorway service stations!
    Emptied mine the other day,and i'm pleased to say it was nowhere near as bad and as much! Oily smelling water is the best description of the contents!
    S3 Brilliant Red - 340bhp
    Custom Code Phase 2 + PSS, Autotech pump, Hybrid Forge/ITG Maxogen CAI /Reflactagold, Sprint Booster, Forge Quickshift, Forge DV, Denso Iridium sparks, PCV mod/oil catch can, R8 oil filler cap, Sachs performance clutch,Exhausts UK custom stainless TBE, Braille no-weight battery,PIAA mirror white DRL's,exterior + interior leds, AndyMac's Sub upgrade, H&R springs, VMR VB3 18x8.5 gunmetal alloys wearing BF Goodrich G-force 235/40
  4. #43
    Nov 2008
    538
    Popped the bonnet today to have a check of the level gauge a found it was right at the top, three quarters of the sight gauge had a clear liquid in it and the other quarter was brownish. With all the cold weather we have been getting im guessing there will be alot of water produced in the catch can causing it to fill quicker, I poured it into an empty can 330ml and it filled it to the brim and still had a good bit left to drain. took a quick picture to show off the smelly mess
  5. #44
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    liposuction ....residue
  6. #45
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    are these designed for the 2.0 tfsi or can you get them for any engine type? how does the catch can manage to only catch the crappy old oil rather than the good oil?
    rs6's, H&R 35mm, lamin-x, vinyl wrapped grill, cupra splitter, black wing mirrors, de-badged, bmc air filter
  7. #46
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    David wrong pic mate, that IS Irn Bru. Seriously though that doesn't look to healthy; is that exactly how it came out, or is it starting to freeze solid?
  8. #47
    Nov 2008
    538
    Thats it straight out the can, all the contents mixed together and it ended up looking like this ha glad it isnt going back into my engine
    Davie
  9. #48
    KRL
    KRL's Avatar
    Jul 2007
    523
    If you let the gunk sit for a little while it will separate. The white frothy gonk will go to the top and the fuel/oil/water will go to the bottom.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
  10. #49
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    How do you empty the forge can? and where do you dispose of it?
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
  11. #50
    Nov 2008
    538
    Quote Originally Posted by Phil_T View Post
    There is a screw in plug at the bottom of the unit. Wherever you wish i poured mine over the fence haha
  12. #51
    Phil_T's Avatar
    Oct 2009
    236
    Quote Originally Posted by david_phillips95 View Post
    haha, can you link me to all the 3 forge items in your picture as I cant seem to find them for the S3, also does the washer bottle come with the catch can?
  13. #52
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    So, How often do you need to do this? How may miles had you done?
    It must drink oil now surerly?
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
  14. #53
    Nov 2008
    538
    I phoned Forge and ordered saves time scouring there website plus they are very helpfull.
    Quote Originally Posted by DeckedS3 View Post
    I just check it every couple of weeks, doesnt use anymore oil than standard. It took about a month to fill the catch can last time so that was probably around 800-1000miles.
    Davie
  15. #54
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Davie
    Thanks, What would happen if you didn't empty it? Would it create issues? (lets just say you forgot) or did a run down to the south of France, you wouldn't want to be empting it out half way down there....
  16. #55
    Nov 2008
    538
    I wouldnt imagine it would do the engine any good. I think the reason for it filling so quickly is due to the cold weather, due to the hot air passing through the catch can and the cold air outside chilling it causing condensation, this would explain the water being caught in the can . When the outside temps increase the amount of waste caught should decrease. as the temp inside the catch can will be similar to outside temps.
    Davie
  17. #56
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    As mentioned above , there is a threaded screw at the base, just remove this to drain the tank , then dispose of the residue responsibly
  18. #57
    warren_S5's Avatar
    Oct 2007
    7,163
    My can has been filling a lot recently due to condensation. I've emptied it 3 times in the last 6 weeks.
    As some of you know I've been having a few minor issues with the car in the last couple of months. There has been a bit of a flat spot, a very high pitched whistle, and an inconsistent idle.
    My mindset was starting to turn to the viewpoint that, another day, another peculiarity to deal with, but today after leaving work in Cheltenham I hooned over to Gloucester to see Forge.
    The high pitched whistle had me sensing I had a bit of an air leak, as under full load there was a piercing whistle which only abated when you lifted from the gas pedal. Stop starting in traffic was a tad jerky too which was a tell tale sign.
    My initial point of concern was the blanking cap provided by BSH for the catch can.
    I asked the guys at Forge to spec me up a kit (as I'd seen it done by someone else - possibly on here).
    Forge supplied:
    1) 22-19mm reducer hose (black) - Part no. S22-19B @ 6.50 + VAT
    2) Blanking Plug 20mm - Part no. FMTB052K20 @ 4.73 + VAT
    3) 2 x No.30 Hose clamps - Part no. FMHC2230 @ 1.29 + VAT (Each)
    I decided that as the hoses supplied by BSH to attach to the catch tank were also a bit weak (and possibly not oil resistant), I would also replace these with some new silicone hosing.
    I purchased:
    1) A 1 metre length of 16mm Straight Flouro-Silicone Hose (Black) - Part no. SH-16/FL_Black @ 34 + VAT
    2) 4 x No.25 Hose clamps - Part no. FMHC1725 @ 1.25 + VAT each
    TOTAL COST OF ALL PARTS: 58 (inc VAT)
    All in all the guys were very helpful getting me sorted with the appropriate parts, and ensuring everything fitted and matched.
    I'm pleased to report the idle is now improved in terms of the fact it sits solid. The car is also much smoother to drive and feels far more consistent on boost.
    For those of you (like myself) who have purchased a BSH catch tank on the cheap group buy on Mk5 Golf GTi, these additions are money very well spent. To be honest I've not been that impressed by the BSH catch tank with respect to the outright quality of ancillary components it's supplied with. It's functional but certainly not exceptional. If I had my time again I'd buy the Forge one (take note if you are thinking of buying one).
    Whilst the rev counter sits solid, I still have a slight shuddery burble at idle, and so I decided to rip the plugs out the other day and check them. I have the Iridium 7's fitted (one step cooler), and they still looked cooked (they have only done 3k miles). It was recommended I try out an NGK Irdium 8 (BKR-8EIX) so I have these in now. The issue seems slightly more pronounced with these, but once the car is running its fine.
    I also had the cam lobe out to check and replace, and it had got some quite pronounced wear in the inside, but then its running the HPFP so it is to be expected. The inlet cams showed no signs of any scoring so I'm fairly content with that.
    I'm resigned to one of 4 things:
    1) Coil packs may be weak
    2) Injector spray pattern may not be 100%
    3) Maybe I need to switch to aftermarket DP & cats (Dependent on how long I keep the car)
    4) Maybe the valves have coked up (I'm planning to have the head bore scoped soon)
    It doesn't affect anything other than idle, she still goes very well, so I can't complain.
    Audi S5 3.0V6T Coupe Black Edition
  19. #58
    Nov 2008
    538
    My car is going back to standard now so my forge catch can kit & charcoal canister cover are being sold. For more info see the for sale section or drop me a PM.
    Cheers Davie
  20. #59
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    I have an unused Forge catch can as well that needs a good home as the S3 has gone
    before I had time to fit it.
    Gaz m
    Black 996 C4S
    B6 S4
    Black S3 Revo 2+ sold
    All options + Miltek TBE, Revo 2+, HPFP, RNS E, Bose, Alpine Ipod interface, TTRS Brakes
    For sale unfitted Forge catch can kit, open to offers?
    also standard S3 factory exhaust?
  21. #60
    rodaz's Avatar
    Jan 2012
    13
    Quote Originally Posted by gaz m View Post
    Gaz m
    Hi
    Why did you remove the Catch Can?
    09 S3 / Eibach Pro Kit, PCV Fix, Forge Twintake, TTS engine cover, Sachs clutch with LOBA one mass fly wheel, rear camera, etc
