Hi
I noticed the Engine Management Light has become lit on my dash recently, therefore I scanned for DTC's. The VAGCOM output below shows all the details for my A3 2004 2.0 TDI (80,000). I am not noticing anything major with the car, however the engine when idle is not as smooth as it once was. Could you offer some advice? I am hoping the EGR valve or throttle body may require cleaning. Has anyone had any experience of this error code before? I reset the code, but it came back around 30 miles worth of driving later. I need to drive to London from Manchester next week, is this the kind of fault I am ok driving with?
Wednesday,11,November,2009,20:52:01:59303
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: XXX
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 7D
VIN: WAUZZZ8P******* Mileage: 130810km/81281miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Coding: 0000072
Shop #: WSC 06435
1 Fault Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - - - Intermittent
Freeze Frame:
RPM: 1575 /min
Torque: 44.0 Nm
Speed: 55.0 km/h
Load: 10.6 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Mass Air / Rev.: 315.0 mg/str
Mass Air / Rev.: 535.0 mg/str
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.LBL
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Coding: 078A4F00A2141000000000000000000000
Shop #: WSC 00000
Part No: 8P2 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.LBL
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
Shop #: WSC 06435
Address 16: Steering wheel Labels: 1K0-953-549.LBL
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
Shop #: WSC 06435
Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0140
Coding: 0004403
Shop #: WSC 01234
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Coding: 7D0F0B40070101
Shop #: WSC 06435
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.LBL
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000112
Shop #: WSC 00618
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Address 46: Central Conv. Labels: 8P0-959-433.LBL
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 06435
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
Part No: 8P0 959 802 A
Coding: 0000112
Shop #: WSC 00618
Address 55: Xenon Range Labels: 8P0-907-357.LBL
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000001
Shop #: WSC 06435
Address 56: Radio Labels: None
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Coding: 0000201
Shop #: WSC 06435
Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
End --------------------------------------------------------------------------------------------------
Chassis Type: XXX
Coding: 0000072
Shop #: WSC 06435
1 Fault Found:
Freeze Frame:
RPM: 1575 /min
Torque: 44.0 Nm
Speed: 55.0 km/h
Load: 10.6 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Coding: 0023174
Shop #: WSC 06435
Shop #: WSC 00000
Coding: 16711696
Shop #: WSC 00000
Coding: 0011602
Shop #: WSC 06435
Coding: 0000012
Shop #: WSC 06435
Coding: 0004403
Shop #: WSC 01234
Shop #: WSC 06435
Coding: 0000112
Shop #: WSC 00618
Shop #: WSC 06435
Coding: 0000112
Shop #: WSC 00618
Coding: 0000001
Shop #: WSC 06435
Coding: 0000201
Shop #: WSC 06435
