JMB RetrofitsSky Insurance
Results 1 to 13 of 13
    Nov 2008
    Surrey
    147
    Squeaking noise when starting....??
    Hi guys,
    On my 3.2 when starting it there's a sqeaking noise...I'm assuming it's the starter motor...!!!
    Has anybody else had this problem.....
    Doesn't affect starting the car but is just annoying....
    A3 3.2 DSG S-line
    edition's Avatar
    Nov 2007
    1,417
    Is it just sqeeking when the starter is in?
    Nov 2008
    Surrey
    147
    Quote Originally Posted by edition View Post
    Yes...Only sqeaking when the starter is turning... Is it just the case of taking it off and squirting some WD40 on it. Might be a dry bearing..???
    A3 3.2 DSG S-line
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Just had a look at the manual Gary and looks like an easy job to take the starter out so thats what i would try first. try and get a little oil on the commutator bearings and a dob of grease on the pinion.
    Nov 2008
    Surrey
    147
    Quote Originally Posted by paddy View Post
    Cheers mate...Is that from the " owners manual " ????
    A3 3.2 DSG S-line
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    No but then the owners manual doesn't tell you anything about the starter other than how to get it out.....so going on past experience i would lube the moving parts.
    Nov 2008
    Surrey
    147
    I've got no pit or ramps mate....just a trolley jack and axle stands...That'll do..won't it?
    A3 3.2 DSG S-line
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Gary
    Send me a PM with an e-mail address and i will send you details. you go in under the bonnet, dont need ramps...
    Nov 2008
    Surrey
    147
    pm sent mate
    A3 3.2 DSG S-line
    Aug 2009
    169
    It will be the dual mass flywheel if its a squeaky screech that sound in time with the crankig of the engine and stops as soon as started.
    S3, 4 wheels, magical B8's, Eibach, Pipewerx equipped, glass windows, metal engine, silver paint.
    Nov 2008
    Surrey
    147
    Quote Originally Posted by Kunit View Post
    It does exactly what you said....How do i get rid of that then....Sounds expensive
    A3 3.2 DSG S-line
    Aug 2009
    169
    Replace the dual mass flywheel, it ain't too cheap but i'd have a specialist or dealer listen to it first hand to confirm.
    Nov 2008
    Surrey
    147
    Well it's off for a service in 2 weeks so they can look at it then, but I'll try the starter motor tomorrow...you never know...I could be lucky with it...!!!!
    But knowing my luck it'll be the expensive option
    Anyway cheers for the suggestion...
    A3 3.2 DSG S-line
