Hi all, i recently got an error code on vag com saying that the G62 sensor was faulty, basically the top error of these 2. I changed what i thought was the sensor which is just behind the throttle body. The car is an A3 03 plate 2.0 tdi. Can anyone confirm if the sensor i changed sounds like the correct one? Thanks in advance.
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 7641
Revision: 12345678 Serial number: AUX7Z0C7FN50KD
Coding: 0000072
Shop #: WSC 06435 000 00000
2 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 000 - - - Intermittent
Freeze Frame:
RPM: 798 /min
Torque: 26.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 37.8°C
Temperature: 27.9°C
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
P1951 - 000 - - - Intermittent
Freeze Frame:
RPM: 1176 /min
Torque: 196.0 Nm
Speed: 29.0 km/h
Load: 54.5 %
Voltage: 14.21 V
Bin. Bits: 11000000
Temperature: 54.0°C
Duty Cycle: 9.6 %
Coding: 0000072
2 Faults Found:
Freeze Frame:
RPM: 798 /min
Torque: 26.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 37.8°C
Temperature: 27.9°C
Freeze Frame:
RPM: 1176 /min
Torque: 196.0 Nm
Speed: 29.0 km/h
Load: 54.5 %
Voltage: 14.21 V
Bin. Bits: 11000000
Temperature: 54.0°C
Duty Cycle: 9.6 %
