Chris NottBadger5
Page 1 of 2 12 LastLast
Results 1 to 40 of 42
Like Tree4Likes
Thread: Cup holder mod for facelift A3 / S3
    Oct 2009
    Woking
    25
    As you know in the 2009 facelift A3 / S3 Audi has opted to fit the cardholder instead of a cupholder.
    Searching for “cupholder” on the forum, I found boggym’s excellent “retrofitted cupholder” write up.
    This got me thinking, could this mod be done on the new 2009 facelift switch assembly?
    I took the switch surround off and discovered that the height and width of the 2009 cardholder enclosure is the same as the cupholder, so it does fit. The problem is with the new curved shape of the card holder front and the switch surround. Because the cupholder was designed with a square front there is an obvious clearance issue, but with a bit of modifying to the front and the right-hand side of the cupholder, it can be made to fit properly.
    It took awhile figuring out what to do but here is my modified cupholder in a 2009 S3.
    Ok so it’s not the best mod you can do but it’s my first ever mod and I am rather pleased with the result.
    Here is a list of parts and what had to be modified.
    Parts:-
    Illuminated Cupholder Part number: - 8P0 862 534C 5PR
    Approx Ł27 inc VAT from Audi Parts Dept. or find a cheap one on ebay
    Tools used: –
    Mobile phone fascia removal tool. ( Or be careful with flat bladed screw driver)
    Sharp bladed Knife
    Metal ruler
    Dremel
    Wet and dry sandpaper to tidy up edges.
    1. REMOVE CARDHOLDER
    The switch surround is just clipped on so gently prise it off using removal tool. Be ready to catch the hazard warning switch as it will ping off as you remove the surround.
    Eject the cardholder then remove it by pressing down on the two tabs and pull out. Unclip the wire for the LED on the back
    2. CREATE CLEARANCE FOR CUPHOLDER
    Although the cupholder will fit when the switch surround is put back, it will not eject. So you need to trim part of the right hand side of the cupholder to allow it to eject properly past the curved switch surround. Score a line with the knife to mark what needs removing. You can use a dremel or a knife to remove the excess plastic. I found the dremel started to melt the plastic so I used the knife to get a clean cut. It is tough plactic but scoring back and forth you will eventually cut through. Tidy up the edge with wet and dry sandpaper
    The arrow in the picture shows the locating pin for the bottom flap is no longer held by the side arm. Don’t worry the side arm is not the support for the pin.
    Fit it back in the car and check that it ejects past the switch surround without catching.
    3. FITTING THE CARDHOLDER FRONT.
    Getting the cardholder front to fit on the cupholder requires a fair bit of modifying and patience.
    Trim the following parts.
    A – Cut away until they are flush
    B – Cut away so they follow the angle of the clear plastic
    C – File down the clear plastic and black sides to the red line
    D – On the right hand side, cut away the 2 sections illustrated. On the left just cut away the top section.
    E - This sometimes caused mine to stick when ejecting so you might need to cut 1mm off the little tab.
    Next trim down the top and make two slots so the cardholder front will sit at the right height when located in the switch surround.
    I found that a metal ruler placed on the top will allow you to cut away the required 1 mm.
    Work out where the slots need to be made. The dremel was ideal for cutting the slots
    Once all the modifications shown above are done, the cardholder front should fit.
    A – Tabs trimmed down flush.
    B – Tabs trimmed following angle of clear plastic
    C – Clear plastic / Black tabs filed back
    D – On the Left top section removed, on the right top and bottom sections removed
    F – 1 mm trimmed off the top
    G – Slots cut to locate tabs in cardholder front
    H – Put the cardholder front on and see how much needs to be trimmed so it clicks in place properly.
    4. MAKING THE CUPHOLDER “LOCK” IN PLACE
    At this point, the cupholder with the cardholder front should fit properly in the switch surround and it should eject without catching. Now, just like in boggym’s "Retrofitted cupholder” guide you need to trim the back of the cupholder where it hits the switch surround.
    I
    tapered both sides and tidied up with wet and dry sandpaper.
    So that’s it. Admittedly there is a lot more work required than the preface lift mod, but if you really want a cup holder then these are the lengths you have to go to ...
    Artimus and ankarage like this.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    superb write up, nice one.
    martyboy's Avatar
    Feb 2009
    Scotland
    528
    Add martyboy on Facebook
    ive already got a cup-holder, but what a fantastic write-up!!!
    Just taken delivery of my Glacier White S-Line Sportback
    Feb 2011
    6
    Cheers R4SAN. Just done this mod on the misses 58 plate A3, great instructions. Must admit for a German car there are some daft design flaws, you can use either the arm rest or the existing cup holders, and the shelf in the glove box is too small for the service book pack. Other than that, its a great car.
    May 2010
    2,502
    Quote Originally Posted by jbconno View Post
    the service book belongs in a little section of the passenger door card. if you look at the storage area, at the back there's a little recessed area. it fits perfectly in there
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    I was going to do this but it looks too much of a ball ache
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Feb 2011
    6
    I didnt notice that, I will have a look. She wanted me to hack the divider out on the shelf in the glove box !
    27,114
    Also using this with cans is not advisable as my tests found out, as hard braking will potentially end up with liquid leakage on the radio, cant understand why they put cup holder on the single din units above the radios, even water bottles used to fall out often.
    Feb 2011
    6
    Guy I know went through 3 radios on his pre FL A3as the holder is above the radio. Radios and Coke dont mix well !
    Cardiff, United Kingdom
    392
    Do Audi not make a genuine cup holder for the A3?
    May 2010
    2,502
    Quote Originally Posted by welshwoody View Post
    not for the double DIN, and the latest MY11+ A3s don't even have a card holder anymore
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Isnt the cupholder in the MY11's the same as my MY09? under the arm rest?
    May 2010
    2,502
    Quote Originally Posted by 1animal1 View Post
    there used to be a dash mounted cup holder. that's what's generally referred to as "the cup holder" - not that silly little indent in the console that's the wrong shape for every type of drinks holder known to man
    27,114
    TBH I never use the damn thing under armrest, what a totally ridiculous place to put it, they could of put something just behind the gear knob as such, redesign that area to suit, but I reckon could of squeezed something in there so its more directly accessible & not enclosed by armrest etc.
    May 2010
    2,502
    the american centre console makes me laugh too lol
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Totally agree, **** place to put it, almost as bad as the 8L glovebox indentations..... great if not moving and with a 3 inch cup
    27,114
    lmfao so true 3 inch cup lol remember that very well.
    Feb 2011
    6
    Its a dogs cock design, why couldnt they have used a similar design to the Golf/Octavia ?
    May 2010
    2,502
    because the A3 is meant to be better. by which they mean worse. oh well it's not as if we pay more for the privilege
    RAPS3's Avatar
    Moo Moo Land
    1,077
    I think I'm going to so this mod too.
    Missed this thread the first time around - good thread resurection
    Oh and excellent write up bud - thanks
    Paul R
    S3 Sportback - Sprint, Buckets, Bose, Rain & light, Alu rails, Piano trim, FT Warning, Bluetooth prep
    S3's now sold - roll on the Golf MK1 Project
    27,114
    I rest my case
    27,114
    Quote Originally Posted by RAPS3 View Post
    Still loving that pic Rap.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    I did this a while back, very easy to do and very effective.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    it is a bit gash though, my 8L cupholder on the dash was really good in that it had a few flaps which allowed diff cup sizes...isnt this particular one really flimsy material?
    Feb 2011
    6
    Dont knock the Octy. I loved my VRS TDI. Fantastic car !
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    lol the tdi was never really a vrs though was it
  28. #27
    Feb 2011
    6
    Remapped to 200 bhp it was ;-)
  29. #28
    rdfcpete's Avatar
    Apr 2008
    123
    Has anyone got a spare or unused one of these modded efforts? Its beyond my skillset so ill
    happily pay for someones time and postage if I could
    obtain one?
    Thanks.
  30. #29
    rdfcpete's Avatar
    Apr 2008
    123
    Still after one of these, cash waiting if anyone wants to bang one together - I'll obviously cover your time, parts and postage?
    Pete.
  31. #30
    27,114
    Use this section please Pistol Pete
    WANTED ITEMS: POST YOUR WANTED ITEMS HERE (A3/S3 8P)
  32. #31
    rdfcpete's Avatar
    Apr 2008
    123
    Apologies Nige, should know better
    Looking at an OEM ashtray from an Octavia as a workaround atm...
    Pete.
  33. #32
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    That's all well and good. I thought about this mod but decided I wanted full access to my heating control.
    So I installed the USDM centre console which has built in cup holder:
  34. #33
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,426
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Quote Originally Posted by Boydie View Post
    I remember this thread! Was incredible
    That picture makes me want to do it again...
    Boydie likes this.
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
  35. #34
    rdfcpete's Avatar
    Apr 2008
    123
    What would solve the problem is a full size second cup holder in the area with the drawer.
    Does a console tray exist with two full size cup holders (same size as the bigger one in the image below)?
    Cheers.
    Pete.
  36. #35
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Quote Originally Posted by rdfcpete View Post
    Cheers.
    edit: I'm considering something (spring loaded or drop down) that'll screw to the bottom of the shelf in the glovebox.
    2009 A3 SB 2.0T DSG S line
  37. #36
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Something like this, that won't take up too much space when not in use >>VW GOLF MK4 (1999-2004) CUP HOLDER BRAND NEW FACE CENTRE CONSOLE DASH DRINKS | eBay
  38. #37
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,426
    Nooooo.... I love that small one!
    Someone at Audi had their head screwed on and made it the exact size as a can of RedBull... Another piece of genius similar to the rear view mirror flap...
    Now only if they had thought about the Handbrake / Armrest situation
  39. #38
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    227
    I like the US style! Whats wrong with that?
    Boydie likes this.
    Best regards
    J$B
    Norway
  40. #39
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Quote Originally Posted by A3SBQ View Post
    Its a pain in the ass to fit and doesnt and wont fit perfectly in the foot wells
  41. #40
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    I think its from this page on in my thread:
    My new S.Blue S3!!
