Monster MotorsportVolks Autos
Results 1 to 14 of 14
    Essex
    12
    Bluefin superchips on S3
    Hello folks,
    Had the S3 for 10 months however the turbo lag is irritatingg to the point I want rid of it, recently had a go of a TT225 and is not nearly as prominent,
    Anyways can anyone reccomnend superchips stage 1 or the bluefin as a solution? I hope so..
    thanks .........
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Is yours an 8P or 8L S3 mate?
    8P2 S3
    Essex
    12
    Eerrm not sure...its a current 07 model manual box .. 2.0 turbo
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I see, that's 8P yes. Turbo lag? Are you sure!?
    8P2 S3
    Essex
    12
    Yes sure.. its just been serviced and no abnormal reports...
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Can you explain what you mean by turbo lag? The S3 doesn't have a very laggy engine!
    8P2 S3
    Essex
    12
    ok.. below 2500 rpm nothing... then woosh even tho my foot has not pushed it any further down any I simply want more poke at lower revs like the gold GTi 197 etc ... wondering if the superchips sorts that out????
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    That's not turbo lag mate, that's spool up time. Have a read of this thread: S3 turbo lag.... Really?
    Superchips remap, or any remap really, should sort it yeah. Brings the spool up time lower down in the revs.
    8P2 S3
    Essex
    12
    thanks.....
    Oct 2009
    North West UK
    56
    I also came from a golf gti to an S3 and was feeling the lag (I think we're talking about the same thing re: spool up time). I'm sure after reading the reports on here that a re-chip will help, however if I understand it correctly the S3 possesses a larger turbo in order to provide the additional top end uuuummph. So I think it comes with the territory i.e. Big turbo = big power & bigger lag, Small turbo = less power & less lag. Options to mitigate the use of a larger turbo would be a dump valve (allows the turbo to 'free wheel' for longer by removing load from the compressor), or if you're the fortunate owner of a world rally car, an anti-lag system which injects fuel into the turbine side if the turbo, keeping it spinning when the throttle is closed.
    Essex
    12
    mmmm ok.. I understand now its spool up time not lag which is none exisitant realy on boost..
    I fancy the chip however If its arrives wigger bang but longer spool up time Ill be even more irritated...
    I was hoping somone on heres had it and can exsplaine how it is after stage 1 .. ta anyway
    Jan 2009
    234
    Quote Originally Posted by style30 View Post
    Go for a demo of stage 1 Revo, Giac etc. I am sure this is the best way to see for yourself.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    The spool up time is reduced mate so you'd like it 100%!
    8P2 S3
    May 2009
    Birmingham
    95
    i'm personally looking into a bluefin also...if you didn't know already Superchips offer a 7 day no quibble gaurantee so if it doesn't fix what you want it to then you can return it for a full refund...
    Collected 14 July - 2009 MY10 A3 1.9TDIe Sport 3dr in Brilliant Black
    Factory options: Cruise Control, Debadged, Chrome Exhaust tips
    Mods: CC Tuning remap.
