Chris NottSky Insurance
Results 1 to 13 of 13
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    2.0 tdi diesel fuel filter change procedure
    does any one know of the procedure to change the filter element on this fuel filter type (see photo below)
    1998 AUDI A4 1.9TDI BLACK -LIMO-
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Can't see the pic but basically, take the cap off the housing, remove old filter, replace with new, start up the engine, bingo!
    Its easy.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    711
    Hi!
    First of all you need everything to be clean around. then you have to remove all 6 screws and lift the top. After that, use a hose or something to remove some of the fuel inside or it will spill over and make a mess around.
    Once you have the fuel out you need to pull hard on the filter to take it out. Put the new cartridge in place and be careful to fix it in the proper position. It has only one correct position. You will notice on top of the cartridge 4 holes which should match the 4 hoses you see in the picture above. you may need to push had on the cartridge to fix it in place. Put the seal rings you should have in the box with the cartridge on top to match the holes than you can put the cap back and screw it into place.
    Be careful not to get dirt in the filter and to match the holes on top.
    That's about it!
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Aug 2009
    Stroud
    249
    Would anyone have a picture of the fuel filter as the one I have purchased doesn't look correct ?
    thanks
    6+1 Gears
    Jun 2009
    Romania
    711
    I had the same problem when I've changed mine. There were two filter types and had to buy both just to be sure that I have the right one. I talked to the sales man that I'll be back with the remaining filter and he agreed to return my money.
    One was a thin and long and the other one was shorter and... fatter.
    The first one was the good one.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Gonna get mine powdercoated black, they all go crusty!
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    Quote Originally Posted by DaveA3-TDI View Post
    thanks
    here you go m8 this is the one i used
    C9766ECO
    26,720
    So what mileage have people changed there's at & any difference in running & no I dont mean power just sounding better or anything really to warrant changing now.
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    The only reason i changed mine was i ran the fuel tank just about bone dry and pulled all the ****e from the bottom of the tank.
    Symptoms were loss of power at 4000 RPM.
    Aug 2009
    Stroud
    249
    thanks for the picture, that is the same as the one I have bought so must be correct
    6+1 Gears
    Jun 2009
    Romania
    711
    Here is recommended to change all the filters at 15,000 km (~9300mi). Last time I've changed mine (diesel filter + oil filter + oil) at about 9,200 mi. The fuel filter was quite dirty. After that the engine seemed to run a lot smoother, but again, I've changed all filters...
    26,720
    Quote Originally Posted by RGC View Post
    Thats a good enough reason for me, lmao
    Quote Originally Posted by Johnny Bravo View Post
    You just sent some of my money again, lol, thats fine cause going to audi to pickup my R8 coolant cap so no sweat & easy job so why not huh.
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    146
    Here is the part number for the VAG filter 1K0 127 434 A - 1KO127434A
Tags for this Thread
