Chris NottMonster Motorsport
Results 1 to 20 of 20
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    NO led number plate LED bulbs work in 09 S3
    No led number plate bulbs work in 09 S3,
    Matt and have tried the following.
    Used original LED bulbs that worked 100 % in my 2008
    http://www.convert2xenon.co.uk/led-p...-led-bulb.html
    Although they worked in my 2008 car and still work in Matts 57 - S3 they do not work in my 2009 S3.
    Have also tried adding 150h resistor on one , then on both .. NO JOY.
    Took out the above bulbs as they have a built in resistor and added the one's that toby cruse used ( metal ) with 150h resistor on one , then on both .. NO JOY.
    They all work fine , but bulb error in dis.
    Kind of lost on this One... Does anyone have a 2009 - 59 plate with a working number plate LED ?
    Or has any one used a different resistor value with no errors ?
    Thanks peeps
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Try a lower value mate so it's drawing more current
    8P2 S3
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Thats a shame Pat, looking forward to seein the beast
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    staz.
    Say 100h ? or even lower ,
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Get 2 100s to give you a combined resistance of 50 ohms as the 2x150s didn't work.
    That'll be 2.88 watts.
    If that doesn't work add one or both of the 150 resistors to give 37.5 and 30 ohm total.
    The last would be 4.8 watts which should be the last resort really. Check the temp though!
    8P2 S3
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Ok ,
    So i have tried >
    1 * 100 per light = ERROR , but nice crisp white colour.
    1 * 150 + 1 * 100 on one light AND 1 * 100 on other light and NO ERRORS
    BUT THE.
    1 * 150 + 1 * 100 is now a bluish colour WHILE the 1 * 100 on the other light is crisp white.
    I can have both with 150 + 100 with no errors BUT then they are both bluish , so that defeats the object , although better than yellow !
    ( also tried a single 220 resistor on each light , ERRORS )
    Mar 2009
    Staffordshire
    1,177
    I have LED number plate bulbs working fine on my 09 A3. I think I'm using 2 x 120 ohm resistors.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Ah ok are they 2 watts ? . And what colour are they. ?And which led are you using ?
    Mar 2009
    Staffordshire
    1,177
    These are the ones - http://www.ultraleds.co.uk/37mm-leds...te-p-1496.html
    They are blue ish white - but look wicked. More white than blue. I can take some pics if you want? They are quite bright though, but nothing too bright.
    26,716
    Really you need to test the resistance with the original bulbs in place to work out what you need to use.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Quote Originally Posted by scott1andrews View Post
    I have some of those as it goes , ill give them a try , i only have 100h resistors or 150 though , are you sure you are running 120h ?
    Nigel , i would have no idea how to check which resistors work , the ones i am running show no errors , but they are now blueish , and in my 08 car they where crisp white.
    Worked 100% and still do in Matts , must be a facelift issue.
    Mar 2009
    Staffordshire
    1,177
    Quote Originally Posted by crypric23 View Post
    I'm not too sure. Could be 150 ohm, could be 120 - can go and check if you like? I know I had 100, 120, 150 and 180 ohm resistors.... so it's one of them, lol.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    LOL , i would be interested to know the exact set up you have.
    As many people including myself have had results on pre facelift , but as of now you are the only person i know of that is running them on a facelift , i would also like to see a pic. As mine do work with no errors , but have gone from crisp white on my old car to a blueish colour , maybe i am just being fussy and they are the same as yours.
    I am just annoyed that they where white and are now blueish !
    Mar 2009
    Staffordshire
    1,177
    Now that I think about it, probably 150 ohm, as I'm certain I bought 180 and 120 just in case the 150's didn't work so I had some others to mess around with. I've just been out and taken some pics (in the rain!) nothing fancy, just on auto, but let me boot into Windows and copy them over as I haven't got my card reader working on Linux yet.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    You are a gent ! , rain in costa del cheshire !
    Mar 2009
    Staffordshire
    1,177
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Great thanks for that , ill try the bulbs you have with a 150h ( i have both somewhere )
    I will let you know.
    Mar 2009
    Staffordshire
    1,177
    Cool. Good luck!
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Rattles or No rattles, your a good lad Scott, a good lad.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I missed this thread yesterday Crypric.
    I can only assume that there's too much power being used by the resistors so the LED gets the bear minimum. I would suggest that there's a certain resistance that might give you the better colour without errors but you could end up messing about for ages trying to find it!
    Fingers crossed the other LEDs are better for you mate.
    8P2 S3
