Chris NottJMB Retrofits
Thread: Lights Upgrade
    TAC
    TAC's Avatar
    3.2 V6 Burble... hmmmmmmm
    Oct 2009
    302
    Lights Upgrade
    Right have just bought an 06 plate A3 3.2 and want to upgrade the rear lights to the newer LED ones and also the possibility of the front to new style ones. Is this a simple mod that can be carried out easily or a mod that needs lots of changes to take place not just a simple swap?
    If anyone has and pearls of advice that would be great.
    ta
    Tom
    Aug 2005
    London
    263
    Do a search fella, loads of info on the rears, its simple.
    The fronts, however.........
    TAC
    TAC's Avatar
    Oct 2009
    302
    Quote Originally Posted by davej_anderson View Post
    Thanks for that subsequently have discovered other threads on this. A little naive at the use of the forum....
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    There's a linked thread in the FAQs too.
    8P2 S3
