Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    Oct 2009
    North West UK
    56
    Implications of more power?
    Considering a bit more ooooomph from my S3 after being slightly disappointed with the anticipated performance increase compared to my mk5 golf gti. Slightly worried about chipping in regards to the insurance and warranty implications of say a 300bhp conversion, can anyone advise who's had a bit of a boost already?
    Ron
    Oct 2009
    Bristol
    48
    Came across a post earlier tonight (don't ask me to link it as I cant remember where I found it) that shows most stock cars are 280ish and a stage 1 Revo or AMD map will take it to 330ish. Search the forum, you will find more details.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Come on now guys.....1 of you must have told your insurance company ?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Quote Originally Posted by Scottiej1979 View Post
    Unfortunately that is not true - a stage 1 map will take you to around 300-305bhp
    You will then require a full turbo back exhaust, intake and stage 2 map to achieve 320-330bhp
    You will then require a high pressure fuel pump and a stage 2+ map to achieve 340+bhp but then you would also have to consider a new clutch as well.
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Quote Originally Posted by RonS3 View Post
    Ron
    Insurance: Revo 1 will take the car into the first "Percentage Tier" on you insurance, which is 0% - 19 % Increase over stock (IIRC). Last year Direct Line wanted an 50 pa, but raised my excess by 350!!! Binned. Went Adrian Flux and the premium was perfectly acceptable, more importantly the excess is only 150.
    Warranty: Maps will only be found if Audi/whomever are actively looking for it. When you hook it up to their diagnostic (V... summick) there are no alarms or flashing lights identifying you as a sinner. With a Stage 1 map I struggle to see what warranty issues you will have which could be attributed and refused under the basis of it being mapped - except the clutch of course. <<< and that's if you tell them it's mapped in the first place.
    My advise would be to at least try the Stage 1 map as I was of the same opinion that the standard S3 is underwhelming.
    Oct 2008
    888
    Quote Originally Posted by Boydie View Post
    l second this. l saw a little clutch slip after getting here but it seems to have gone, for now.
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    this is a question I was wanting to ask actually, and apologies for kind of hijacking the thread RonS3, but how much effect will a standard Revo (or mapping of similar ilk) have on the wear of the clutch?
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Oct 2009
    North West UK
    56
    AuldReekie
    Thanks for your very informative post, it answered my doubts nicely. How did you find the stage 1 map performace, did it give the car the edge you were looking for or give you a thirst for more?
    Beanoir
    I personally wouldn't be to worried about the clutch with an additional 10 or 15% power, unless you're engaging in frequent traffic light grand prix's. The clutch only wears when it's slipping so provided you don't abuse abuse it I can't see it being an issue. It may have a slightly lower life as the onset of slip may occur sooner because of the additional power.
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    AuldReekie
    Beanoir
    Ron. The difference is night and day. Not only in terms of the extra outright power, but the delivery of that power throughout the rev range. Here is what Paul and I think/thought of it - post 38 if you are short for time). Yes, it can be quite addictive.
    Iggu's Avatar
    May 2008
    Here
    1,224
    Stage 1 Revo remap will transform you car and shouldn't affect the clutch. Stage 2+ however puts so much torque through the flywheel (360 lb/ft and more) that it will screw the clutch after some time even if you don't slip it. Having said that the Sachs performance clutch upgrade is a superb, if costly, modification which I'd highly recommend anyway.
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
