Will headlight switch fit ?
vw754
vorsprung Durch Technik
U.K
hi,ok what i want to know is will the chrome or non chrome headlamp switch with 'auto' function from a golf mk 5 or anothe vw fit and work on the 2.0 tdi A3 (8P)
im willing to buy the switch but could do with part numbers off a switch with auto function so i can order to fit my a3.
I have one for sale brand new.
Auto light;s on it .
What is on your existing switch at the moment , if it is the same as this then i have the chrome version for you
crypic - i cannot see you pic in work but hopefully its the same as mine as i am interested in buying the chrome switch
I have the coming home function button and auto on mine - yours the same?
mines the same (without auto) but i aint got the small button at bottom left,how much do you want ? and have you got the part number to the one pictured?
Well it is a different switch then , and is no good for your car.
The switch is the coming / leaving home button.
i want the coming home lights,that why i want a switch with 'auto' function
Coming gome has nothing to do with the auto position on the dial knob, ch/lh is controlled via the seperate button mate, so you need this & you have to wire this in & code it, plus your module 09 (J519) has to support the function, so you need to check the module with vagcom 1st before changing parts then finding cant be done.
oh right.........nice one ........didnt know that.
how can i check via vag?
And thanks !
If anyone is selling a standard A3 switch without the chrome piece and without the ch/lh button (basically identical to the pic crypric23 put up but without the ch/lh button) I may be interested.
Yes i am selling it along with some other bits before i part ex this week.
S3 pedals
chrome climate control ( to match light )
Facelift switches ( below climate control )
S3 Alloy wheels and tyres
And thanks !
Module 09 long coding check if its an option you can tick or not, also what part no/module version does 09 show you?
ive checked on vag and my car does:lmfao: support that function !
Also what do i need to do if i want the footwell lighting,i know the car supports that and was wondering if the wires/connection are already there or have i got to wire up ?
You hope, lol.
Doubt it, robina3 does a kit for footwell & puddle lights fairly cheap, look him up mate.
746
766
13
2K
673
794
