Volks AutosJMB Retrofits
Results 1 to 10 of 10
    May 2009
    SE London
    225
    How do you remove trim from gear stick?
    im changing my interior trim over, ive done everything but i just cant get the trim from around the gear sick off
    any advice?
    thanks
    27,114
    Yeah, have you got an ashtray in the front of it or the storage cubby?
    If ashtray then open lid & pull the gear trim up from the front & each corner gently & then should come of.
    Also helps to pull the gaitor out as its only clipped into place, bend the gaitor plastic slightly to get it unclipped then the gaitor just lifts up, then just pull it up over the gearknob & leave it like that, then you can pull the trim upwards at each corner as its got a fixing in each corner thats pressure based, be careful only pull a inch or 2 or you'll break the legs of, patients required as its a 50 part.
    May 2009
    SE London
    225
    i can see the clips on each corner but when i bend them back it still does not want to lift
    ill give it a go
    thanks
    May 2009
    SE London
    225
    gave it a go but when i bend the 4 clips back im getting no movement at all
    Synchromesh's Avatar
    Will Race For Cookies
    Jun 2009
    Belgium
    99
    Phantomschwarz Audi A3 2.0 TFSI quattro S-Line | Bilstein PSS B14 | Oem 8x18 ET43 5-Spoke | Facelift taillights | RNS-E MKII | My Thread
    27,114
    have you got an ashtray or storage hole?
    May 2009
    SE London
    225
    ashtray
    May 2009
    SE London
    225
    managed to do it, just needed a bit of force
    thanks
    27,114
    lol, I was gonna ask if you sorted it, but was my info of use as used those methods many times.
    May 2009
    SE London
    225
    lol i left the gaitor on, i got 2 small screw drivers uncliped 1 side and pulled it with a bit of force and then the other side
    thanks
