Chris NottSky Insurance
Results 1 to 26 of 26
    MarkSport's Avatar
    A3 2.0TDI 170bhp PhantomBlack
    May 2009
    Lisboa, Portugal
    127
    ARB: H&R vs. Eibach
    Hey Guys,
    I have Eibach Pro Kit and OEM Dampers.
    Next months i will replace by Coils, maybe Weitec/KW V1.
    I want to buy a good ARB set.
    I have been checking on AwesomeGti, and H&R ARB is mucher expensive as Eibach.
    justified to pay more ?
    2007 Audi A3 | MB POWERED | ECS TAI | Eibach Pro-Kit | 6000k & Leds | Vag-Com Coded
    Custom DeCat Exhaust 2,5'' | Nitroplus | RNS-E w/2010 AN
    Aug 2009
    I have the Whiteline adjustable ones. They seem very good value for money. Mind you, I don't know why not more A3 drivers use the Whiteline products. The Golf 5 guys rave about the WALK...... I must say that it made a big difference on my A3.
    http://www.mk5golfgti.co.uk/forum/index.php?topic=395.0
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    Guys i have a question regarding the eibach springs. What is the difference between the Eibach Pro Kit model and the SportLine one?
    Many thanks.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,775
    Hieght I think.
    I had always considered going for h&r ARB's, never looked into whiteline or eibach personally.
    How much are the whiteline?
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    It is important to has ARB and dampers manufactured by the same brand?
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    @MarkSport - could you please post a pic with your car to see how lowered is your car ?
    Thanks!
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    Quote Originally Posted by influxsg View Post
    Many thanks.
    Eibach Sportline
    Lowers Car by: Front: 45-50 mm Rear: 35-40 mm
    Eibach Pro Kit
    Lowers Front: 30 mm Rear: 30 mm
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    Quote Originally Posted by MarkSport View Post
    No but you have to take into consideration that the companies supplying both springs and ARB's have developed them together for that car so in their eyes, it is the optimal combination.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    Personally we find the H&R ARBs better quality and slightly lighter but they are a fair chunk more then the Eibach's which are a really good set of bars. As mentioned, the Whiteline are also worth considering.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    26,776
    I have had both Eibach & H&R, what can I tell you.
    1st of all goto Damian@dpm mate, far better service than Awesome IMHO, also a great chap to.
    Eibach seemed to knock on the rear & wasnt fitment, fitting rear made a tremendous difference, but knocking was so damn annoying, so swapped to H&R, rear knocking went away but then got a front knocking, now I had gone for the 28mm, so I downgraded to the 26mm front & no more knocking at all & also adjusted the fitment slightly & ground down part of the subframe as the raised pointed area where casting was joined together during manufacturing by audi, was the issue on knocking IMHO, so would actually say its possible the 28mm would have been 100% tbh, such is life.
    But overall I'm extremely happy with the H&R's now & also service from Damian.
    No its not important to use same brand, I have Eibach Pro 30mm springs, Koni FSD shocks & H&R ARB's all from dpm.
    Iggu's Avatar
    May 2008
    Here
    1,224
    I bought my H&R ARBs from Damian at DPM a couple of weeks ago - they are superb. Well worth the extra . (Great service and price from Damian too).
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    Aug 2009
    The Whiteline ARBs fitted without trouble, no knocking. I fitted the 24mm adjustable front and rear. I have the front on full soft and the rear on the middle setting. It suits me really well, almost no understeer and really nice balance. The Whiteline ARBs are slightly shorter than the German offerings by taking out the bend that is needed for the Quattro versions. This means that the 24mm will be comparable with German 26ish mm in roll resistance but with slightly lower weight. From memory, I paid around 175 each. The Whiteline WALK cost me 150..........
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    what is whiteline walk?
    Aug 2009
    http://www.whiteline.com.au/docs/bul...20&%20MKVI.pdf
    http://www.whiteline.com.au/docs/bul...nti%20lift.pdf
    http://www.whiteline.com.au/docs/bul...0Mk4%20MK5.pdf
    I had the Whiteline Anti Lift Kit on my Subaru before and found it worked realy well. Now with a front wheel drive, I notice even more difference.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    Anti Lift Kit, amazing!
    DPM Performance
    T: 01207 561606
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    Anyone any experience with the KW ARB's? they are 260 from demon tweeks
    how much is the whiteline anti lift kit?
    26,776
    TBH boycie ask jamiekip about the H&R arb's, as he said they were great on his S3, for sake of 140 I'd want the best tbh on that car
    Boydie's Avatar
    Boycie
    Dec 2006
    4,775
    I am still dead set on the H&R, just curious as to what else is out there.
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    I have H+R front and rear ARBs fitted which made the car handle a lot better and was a very good quality looking piece of kit. I come from a Seat forum where people used to have knocking issues with Eibach plus H+R are well know for producing very good quality stuff. Every tuning company i know tell me Whiteline stuff is cheap for a reason and to stay away from it, you get what you pay for same as hottuning coilovers on ebay are cheap for a reason.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    The KW ARBs seem very heavy like for like compared to the rest.
    DPM Performance
    T: 01207 561606
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    Quote Originally Posted by Boydie View Post
    http://www.dpmperformance.co.uk/whit...co-p-3624.html
    DPM Performance
    T: 01207 561606
    Aug 2009
    Quote Originally Posted by devonmikeyboy View Post
    I've never had any problems with the Whiteline stuff. It has always done exactly 'what it said on the tin'. I've read a lot of their technical papers on their website and found them very informative. I know from experience that both Eibach and H&R are very good manufacturers but I like the way Whiteline innovate with sound technical foundation. To compare them with cheap coilovers is a bit unfair. Whiteline is clearly a manufacturer that designs products that work well in my experience.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    Got to agree, Whiteline is far from cheap and the quality on the products is great.
    DPM Performance
    T: 01207 561606
    Sep 2009
    Singapore
    21
    Would like to check if any of you gents have had only the rear ARB's fitted? I know someone who had the KW front and rear ARB's fitted, but through experimentation, found that only the rear ARB's were truly necessary. In the end, he removed the front ARB's and found handling and ride comfort to be much improved.
    I'm thinking of getting the H&R Front n Rear ARB's but am little hesitant based on his input. Otherwise I may just get the rear fitted. Is ride comfort substantially affected with both front and rears? I'm currently driving a stock S3 8P
    Comments?
    Aug 2009
    What is the diameter of the standard front ARB on your S3? I tried my Whiteline 24mm front ARB on harder settings and found it increased understeer. It was best on the soft setting. So you might well be right that an uprated rear ARB and standard front ARB is the best solution.......... On my old Mk4 Golf I found that fitting only a rear ARB was best as well.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    A thicker front bar will increase understeer and a thicker rear bar will increase oversteer. This is why you have to get the correct combination to get a balanced handling car.
    DPM Performance
    T: 01207 561606
