Volks AutosMonster Motorsport
    Oct 2009
    21
    DSG/S-TRONIC?????
    COULD ANYBODY TELL ME THE DIFFERENCE BETWEEN DSG AND S TROINC? CHEERS
    andyb_88's Avatar
    Apr 2009
    Essex
    99
    Twin-clutch pioneer Audi is now the proud manufacturer of a new 7-speed twin-clutch gearbox called S Tronic. Joining Audis other offerings like 6-speed DSG, Multitronic, manual, Tiptronic and R Tronic, S Tronic is another step forward in the pursuit of high performance, lower fuel consumption and satisfying driving experiences.
    The S Tronic is capable of attending to up to 550Nm of brute torque, and handling engine speeds of up to 9,000rpm. This probably explains why the [Nm RS 6] uses a normal 6-speed Tiptronic transmission.
    S Tronic is a twin-clutch transmission system that, you guessed it, uses two clutches to engage and change gears. The gist of it is that while other systems only engage the next appropriate gear when the control unit decides speed, revs and throttle are optimal for that action, twin-clutch systems work a little faster. These engage the next gear as soon as the current gear is engaged, thus in essence lie in wait for the action to be approved so as to quickly slip into engaged selected gear. Simple.
    S Tronic can also be driven in various modes, such as D (Drive) and S (Sport). In normal D mode drive changes are auctioned by the computer, while S allows for quicker shifts that can even be done via optional rockers behind the steering wheel.
    .. and if you cba to read all that...
    The S-tronic and DSG are the same thing as far as VW/Audi goes and it is simply known as S-tronic. It's a twin clutch, sequential auto/manual. Supposedly can change gears in .02 seconds. And thought to be the second most advanced gearbox, behind only Ferrari.
    Black A3 2.0 TDI DSG Sport
    Done and dusted Window Tints | Blacked out rear lights
    24th Oct - AMD Remap Stage 1 | De-cat and Downpipe
    Todo List Face-lift | Black'd RS4 alloys | R8 style lights | Lower 20mm
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Well done lad.
    Oct 2008
    Telford
    2,488
    Yeah S-tronic is just a name change on the Audi side of the VAG stable, Its still the same DSG box fitted to the VAG range.
    Some 09 models come with a revised 7 speed version including the new Ibiza Cupra but the tech is still the same
    B6 1.8T Avant s line gmbh
    Basically the replies given so far are correct, but I would add a couple of points.
    Firstly Audi was not the twin-clutch pioneer. The DSG gearbox was originally developed by VW engineers in conjunction with Borg-Warner for use in it's transverse engined models. Audi also decided to use the same gearbox in it's transverse engine model - the A3 and the TT. It also changed the name to s-tonic in it's models. All the DSG/s-tronic gearboxes are manufactured in a new VW plant at Kessel for use in all VAG models.
    Audi have now done some further development on the s-tronic to produce a version for use in it's front to back mounted engines and it gradually being introduced into various models. Current on some version of the A4 and A5 can be ordered with it.
    Also the newer 7-speed version differs from the original 6-speed version in the type of clutches used. The 7-speed uses dry-plate clutches where as the 6-speed uses wet clutches which are always covered special oil.
    Dave R (h5djr)
