AH FabricationsVolks Autos
Results 1 to 7 of 7
    PocketRocket's Avatar
    Jan 2006
    Lima - Peru
    78
    Question Suspension: Stock or Magnetic?
    Just wondering/comparing S3 stock suspension vs “magnetic ride”.
    Which will be stiffer? Stock or magnetic in “sport” mode?
    Will it worth including magnetic ride on an S3?
    Thanks!
    27,099
    Most have reported back forget it on the S3 but the TT is good, so I would leave of & then go aftermarket, your choice mate, but also have you had a test drive in an S3 with mag so you can see for yourself.
    & I would say mag with sport mode given the design of them.
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    560
    I suspect Mag with sport mode on will be stiffer than stock. But then again, do you want to drive around all day with stiff suspension? Maybe i'm getting old but i enjoy i a comfy ride and option to change it
    You can take the boy out of Essex but not Essex out of the boy...
    Jul 2009
    Swansea
    42
    Mag ride comfort is slightly softer than stock (IIRC from the test drive of the stock car), closer to s-line. Sport mode is much harder that the normal S3 setup. I'm happy with it, as keeps the family comfee, and gives me something better to "play" with on my own.
    Having said that, sport mode is at the limit of whats usable on a bumpy B road.
    Good luck with finding a test drive though!
    Paul
    S3 Sportback (Mag Ride) + A4 Avant 2.0T Quattro
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Personally, go stock then upgrade with an aftermarket kit
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Quote Originally Posted by Boydie View Post
    Ditto that!
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    Jan 2006
    Lima - Peru
    78
    Thanks all for the info.
    @pcmanning, can you manually disable "sport" mode or will it activate no matter what on every bump/turn?
