Badger5Sky Insurance
Results 1 to 7 of 7
    May 2006
    Manchester, England
    30
    Smile VAGCOM Manchester
    Hi Guys its been a while since i last came on here, so im class as a newbi again!!!
    Is there anuone in the manchester area with vag com who would be willing to change the codings so i can have the welcom home lights??? obviously i will pay what ever is the fee, thanks fellas Monkiee.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Check the VCDS forum mate. There's a thread in there for VCDS members
    8P2 S3
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    Quote Originally Posted by MONKIEE View Post
    I will do it for you for some beer tokens fella? PM me if you want?
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    27,129
    Wes is a good chap, very helpful.
    PS. Wes get on msn.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    Well we coded everything up but for some strange reason the leaving home lights work fine but the coming home lights wont work. Its definately coded right, could this have anything to do with the xenons being retro fitted????
    27,129
    Which xenons has he got, which year of car & did you code the 09 module to tell the car he has xenons, assuming they're oem xenons, there was something in the 09 that i ticked caused this issue, cant remember right now but if I do remember I'll post.
    Did you have to just code or touch the wire aswell Wes?
    Whats his module version in 09 & whats the coding mate.
    wesley's Avatar
    Feb 2007
    Manchester
    323
    VCDS Version: Release 908.0
    Data version: 20090911
    Monday,12,October,2009,21:59:46:29101
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P14A148707 Mileage: 142000km/88234miles
    09-Cent. Elect. -- Status: Malfunction 0010
    Address 09: Cent. Elect. Labels: None
    Revision: 00030000 Serial number: 00000000581560
    1 Fault Found:
    02104 - Light Detection Sensor (G399)
    010 - Open or Short to Plus
    We had to earth the wire, the xenons are aftermarket apparently Nige.
    Last edited by wesley; 14th October 2009 at 19:31. Reason: too much jargon and my dad told me off!!
