Chris NottSky Insurance
Results 1 to 7 of 7
    Oct 2009
    7
    HELP PLEASE!!! FOG LIGHT HELL!!!
    Hi fellow Audi Strokers
    In the process of converting 06 Sportback (2.0 TDI Sport) to an S-Line version.
    Had a second hand s-line front bumper repaired and resprayed etc, and it looks champion (especially with the big black grille). Well chuffed.
    Here's the problem:
    S-line bumper had to have s-line fog lights and fog grilles, but the plugs that come with the fogs, have a different plug than the plug from the car's lighting system. Hope this makes sense.
    The guys who fitted it, said i would need a retrofit plug wiring conversion kit, which i could buy from fleabay. However, i can't find it anywhere.
    Anybody else encountered this problem?
    Thanks in advance
    Jmw
    Oct 2008
    Telford
    2,488
    Yeah you can also buy a "repair wire" kit from Audi themselves to do this. You could always bodge them together with bullet connectors then wrap a load of insulation tape round them, job done!
    B6 1.8T Avant s line gmbh
    Oct 2009
    7
    Lee R. Top man.
    Any idea exactly what the part number is for the AUDI WIRE REPAIR KIT? or the exact name?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    That is the name mate. It's just a single wire that has the normal terminal ends that fit into the connectors used on the car. There are different sizes though but I'm fairly sure most of them are the same.
    Found this site:
    http://www.nsxjr.com/Audipins.html
    And on there:
    8P2 S3
    Oct 2009
    7
    Wirey Bits
    Thanks Stazatron.
    You are the man.
    Khufu's Avatar
    West coast of Scotland
    5,693
    i used the exising wires - using thin needle or such, you can remove wire from the holder by bending the locking tab back. You can then bend the tab back out and insert it back into the new holder.
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    When I did the conversion I cut the old plugs of and soldered new repair wires on.
    Fog plugs x2 3D0941165A
    Fog repair wires x2 000979244
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
