EM TuningVolks Autos
Results 1 to 12 of 12
    Jul 2009
    37
    Front Badge Removal
    Hello all, finally got my car... haven't taken a pictue of yet right enough...
    I've got a black 4 rings badge to replace the chrome one on the front grill. What's the easiest way to get the chrome one off? Anyone done this without removing the grill... ie and front bumper
    I tried to prize it off by sticking a thin piece of metal between the badge and the grill, but there is no room
    Appreciate any words of wisdom
    2009 A3 Black Edition - Ibis White
    2006 Vauxhall Monaro VXR
    2004 Nissan 350Z
    2002 Honda Civic Type-r
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    Hi mate, i tried replacing mine without taking the grill off but was a complete mission, in the end the whole bumper had to come off, here's a pic of the back of the audi badge where all the clips are. should give you an idea on how to get it off without taking the bumper off. hope it helps
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Why not just take the grill out of the bumper and then the rings out of the grill?
    Dark Vader Half sibling - MyThread
    Jul 2009
    37
    Quote Originally Posted by benskin07 View Post
    From what I've read, grill out without taking off the front bumper isn't easy and you can easily damage it.
    I'm wondering if removing the cover on the bottom of the car would allow enough access... I may try this tonight to see.
    Thanks for the info/comments EvolutionV
    2004 Nissan 350Z
    G"MAN's Avatar
    GONE LOW BUT GOING LOWER
    Jul 2009
    MILTON KEYNES
    82
    yh its best to take the front bumper of trust me there is a tiney little crew right behind the numberplate block that you cant get to unless you take the front bumber off then then the bumber off take the grill off then at the back of the badge you need to bend the pind straight as that is what holds the badge in..
    hope that helps
    G
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    Quote Originally Posted by V8RM View Post
    With a bit of force the badge will come off without taking the bumper off or removing the grill, I managed it on mine. I ended up using a knife out of the kitchen draw it worked a treat. If you look at the picture in the post above you will see where the clips are. It needs a bit of force but it will come out. Did you get a badge sprayed or buy one ready painted??
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    26,762
    I think a black effect on my A3 might just go very well overall, got me thinking now Matty & boys.
    Jul 2009
    37
    Quote Originally Posted by mattandrew View Post
    Sprayed it. There is so little room, but i'll give it another go, just don't want to mark grill.
    cheers!
    2004 Nissan 350Z
    26,762
    What paint did you use, matt or gloss?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,768
    Our A3's were the same colour nigel? I liked the black look at the front of mine!
    Jul 2009
    37
    Used Audi Black Gloss from Halfrauds.
    Rubbed it down with a light grade of sandpaper, primered, glossed, clear coated. Looks good, although it would look better on my car than my kitchen work top
    Had another go at getting the little blighter off last night, no joy.
    2004 Nissan 350Z
    26,762
    lmao Halfrauds, lol, like that.
    White spirit or just burn if of with a blow torch, lmfao
    Anyway Andy what was your colour code on A3 slim?
