EM TuningMonster Motorsport
Results 1 to 21 of 21
Thread: SD cards
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    SD cards
    I have looked everywhere to find help on this.
    I have the correct cards.
    When in the sat nav , they only show one folder and one album.
    When i go to scan i finds all the tracks for other albums.
    But i can for the life of me not get it to view separate folders ( like playlists )
    I am on a mac by the way,
    Any help before i just give up !
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Being on a mac is your first problem!
    There are two ways to do it. One way uses M3U files and the RNS-E reads those files to sort your music out. The other way, which is the way I do it, is to simply have each album in an individual folder on the root of the card. Then when you navigtae on the RNS-E all you're doing is going through those folders as if they were albums.
    Mine are all in the format of:
    Folder Name: Artist - Album
    Track name: Track number (in 2 digits or it puts 10 next to 1) - Track name.
    Works great for me.
    8P2 S3
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,189
    Have you pressed return on the RNS-E to get back to the list of folders?
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    ahh no i had not pressed the return button ! BINGO , i love this forum !
    In my defence when i first tried it i only had Two album's ( folder's ) and they showed up
    when i put the card in strait away
    Then when i filled up the disk with a load more and put it back in it only showed one album , this is why i was a bit lost , i assumed that you scrolled down the first album track list and the next album would be below it. Never even thought to press the return.
    And Stazz mac's are for cool kids !
    Although i have to use a pc for vag-com , which is painfull.
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,189
    Glad you sorted it, gets most people that one so you're not alone!!
    Previous
    2008 Red S3
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    On mine i have to push TV/DVD twice like a double click on a mouse...that does it :-)
    Aug 2008
    408
    theres a bit of software on here somewere m8, which has been designed for the rnse for sd cards etc, to allow you to modify track names etc, as soon as i find it on here ill post the link up, or can send the program to you via msn etc.
    Cal
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Has to be for a mac though , i have seen the one called Ben something..
    Thanks guys
    MarkSport's Avatar
    A3 2.0TDI 170bhp PhantomBlack
    May 2009
    Lisboa, Portugal
    127
    While on the subject,
    What are the limits of the RNS-E?
    How big a card may have to be able to read?
    2007 Audi A3 | MB POWERED | ECS TAI | Eibach Pro-Kit | 6000k & Leds | Vag-Com Coded
    Custom DeCat Exhaust 2,5'' | Nitroplus | RNS-E w/2010 AN
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    There is loads of info in the search option. i am using 2 * 4 gig standard sd cards
    Oct 2003
    up north...
    767
    it will use 4 gig cards but only the old type (not sdhc) - easiest to look on amazon.co.uk
    there is plenty of freeware to create playlists (one for each cd usually, with the playlist name the name of the cd) and these show up in the default view instead of having to browse folders - makes the rns-e/sd cards work more like a multi-cd changer
    remember max 512 files/folders total per card of any size - anything more and it just wont show up on the rns-e
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    It's been discussed before but I really don't see what benefit the M3U files gives. When I press CD/TV I have a full list of folders titled as albums as I said above, I go into that folder and it shows me the tracks listed in order and then I press on the first one to play!
    8P2 S3
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    Quote Originally Posted by dunk View Post
    I have a problem.
    I have a SD 4GB Card, with 459 songs spread over 30 folders and i cant read it.
    It starts loading, but never shows the songs, why?
    459 songs + 30 folders = 489 files
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    I am completely desperate for a 4 GB SD card but in all the stores that I went they have only SDHC ...
    Any ideias?
    lake_m's Avatar
    Soon to be S3'd up.
    NE England
    62
    http://www.amazon.co.uk/Transcend-4G.../dp/B0012ZL56A
    Read the reviews on amazon - guy bought one for his RNS-E and it works perfectly.
    Andy.
    Lotus Exige S - Gone :::::::::::::: RS4 Avant - Gone::::::::S3 Black Edition - Gone::::::::::TT RS::::::::::::
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Quote Originally Posted by MarkSport View Post
    I have a problem.
    I think the limit for files + folders is about 400....
    LostBok/BahnStormer77
    DaveS3Turbo's Avatar
    Sepang Blue S3
    Oct 2003
    1,062
    On mine there is no CD/TV the button has become media. The screen also looks alot clearer for some reason.
    Just read the differences on the new units and it's a huge difference 32 GB SHDC cards and higher resolution etc.
    2012 Porsche Cayman R Peridot Green MY12
    2011 Porsche Cayman S Basalt Black MY08
    2010 S3 Sepang Blue MY10
    2009 S3 Imola Yellow MY09
    2007 S3 Solar Orange MY08
    2005 A3 2.0T FSI Quattro S-Line 200Bhp MY06 : Misano Red
    2003 A3 2.0Tdi Sport 140Bhp MY04 : Brilliant Black
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    556
    I have a problem.
    Sure you haven't got SDHC cards? If so, they wont work as I had the same problem as you. I tried endlessly with a variety of cards and gave up and reverted to 2GB cards NON SDHC cards. mymemory.co.uk had an offer on for 4 for 20 quid.
    You can take the boy out of Essex but not Essex out of the boy...
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    556
    Quote Originally Posted by DaveS3Turbo View Post
    Do you still get TV under the Media button?
    MarkSport's Avatar
    May 2009
    Lisboa, Portugal
    127
    Quote Originally Posted by lake_m View Post
    Andy.
    I bought 1 through this link for 25 GBP.
    But the Amazon a few days later canceled the deal and returned me the money. And now as to 99GBP.
    Did no one has 4GB SD's for Sale?! Nor is there any way to make the SDHC be recognized by the RNS-E?
    Sepang Blue S3
    Oct 2003
    1,062
    Quote Originally Posted by kkp0897 View Post
    No, just says media which is better really, because when you press media it then shows you a list of AMI / SD / NAV Loader / Etc.
