AH FabricationsVolks Autos
    aristides's Avatar
    Aug 2008
    Greece
    543
    Perforated Gearknob (S-line)
    Guys does anyone of ya got a part number for a Perforated Gearknob (6 speed manual) that is used in the S-Line editions?
    There are a few in eBay but all say they would only fit 8L Audis.
    I dont need red/white stitching just the stock S-line gearknob
    How much would it also cost?
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    redmanphil's Avatar
    Aug 2009
    Cheshire
    45
    I bought a 8L knob from eBay,. Simply undo the staples round teh base and then attach to your current base from the 8P. Its the easiest mod EVER! I'm sure loads here have done it.
    PM if you need more information.
    Phil
    2003 Audi A3 2.0 FSI Sport - Black
    2003 SEAT Leon Cupra R - Platinum Grey
    2000 VW Golf GTI Mk4 Turbo - Dragon Green
    1998 VW Golf SE Mk4 - Black
    aristides's Avatar
    Aug 2008
    Greece
    543
    Hmm i contacted one seller and he told me that the 8L gearknob wouldn`t fit.
    So i should keep my current base and just use the new "head"
    Is it easy to separate those two?
    FOR SALE:
    redmanphil's Avatar
    Aug 2009
    Cheshire
    45
    I got one of these...
    http://cgi.ebay.co.uk/AUDI-A3-A4-A6-...#ht_2400wt_940
    The gearknob comes with new leather & base.
    Now it says its for a 1st gen A3 but it does fit an 8p no probs. If you look as the base you will see it is stapled on with about 3 large staples. You just prize these open & remove the frame at the bottom & replace with the original plastic frame off you existing one. It is literaly a 3 minute job.
    Hope this helps, good luck with the conversion.
    27,126
    This seems to make sense given I know about the staples & they do look the same so cant see why it wont fit mate.
    19
    hi new to the forum and audi, could you tell me if the gear stick in the link would fit an 2004 A4 1.9tdi se 6speed. cheers.
