Badger5EM Tuning
Results 1 to 15 of 15
Thread: 18 inch wheels
    Sep 2009
    10
    18 inch wheels
    hi guys, car came with audi rs4 replica's, been getting this horriable wobble at 50 mph and 70mph
    i have now had the wheels balanced at 3 different places and its still the same?!
    all i can think now is that the spigot rings has got on them are wrong and maybe need another set..... apart from that i am lost!?
    thanks for the any help
    chris
    Aug 2007
    95
    check mate there is no major tyre faults and if not then check the hub mountings for correct size.
    Oct 2003
    up north...
    767
    bent wheel?
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Find somewone who can balance the wheels on the car? that might throw up the fault.
    Crunch's Avatar
    Jan 2009
    117
    If they've been balanced at three different places then it's obviously not the wheel balance thats causing the issue.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    "If they've been balanced at three different places then it's obviously not the wheel balance thats causing the issue." not much gets past you then
    As i said...If you balance them on the car it will show up hub faults ,spline faults etc
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I had a BGT years ago and you could balance the wheels off the car but when you balanced them on the car they were miles out. For example, balancing on the car you are balancing all rotating parts not just the wheel. turned out i had an out of balance disc, only a few grams but enough to set it off and 60 mph . You can then add weights to the wheel to compensate but mark the position of the wheel if you take it off.
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    Quote Originally Posted by audi_a3_chris View Post
    chris
    if they have been balanced at three differnet places and all come back ok surely something on the car is causing the problem, the spigot ring will help but with 5 studs the wheel shud centre it self.
    Do you have any spigot rings on the car??
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    Sep 2009
    10
    yeah i have had the wheels off to check and there is red spigot rings there. there is no bad wear on the tyres..... must be something else.
    Blueie's Avatar
    He who dears' wins!!
    Aug 2009
    Anglesey
    354
    Tracking out?? If your wheel was buckled from hitting a pot hole then you would know about it when balancing the wheel, as they would put a load of weights on. Have you tried swaping the front wheels with the back ones?! Also check your bottom arm bushes had a similar problem with my old seat leon.
    I cant read, an i cant write. But thats ok! Cause im from the west country and i can drive a tractor!
    Click here to make clicking sound
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    Have you got spacers on? werent these causing this on some cars??
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Crunch's Avatar
    Jan 2009
    117
    I had a wobble at 80mph, i ignored it for a few weeks, a few days before i was going to get it looked at, the inner side wall of the passenger front tyre collapsed.
    There was nothing left of it.
    Sep 2009
    10
    no car has no spacers on it.... have called the garage i bought it from and its going into them on tuesday. i think they have bought the cheap of the cheap wheels.
    was in local alloy shop and there rs4 wheels have the centre bore of 57.1. mines has much bigger bore of 66.6 and then collar to covert it to the 57.1 hub.
    will leave it in there hands to fix.
    cheers all for the
    replies
    Sep 2009
    10
    quick update on the car! after fighting with the car garage, in the end up i got brand new set of wheels and the problem has now went away.
    cheers all
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    cheers all
    Good news Chris. What wheels did they replace them with?
    Facelift S3, Sprint Blue, Bucket seats, Sunroof, Sat Nav, Bose, Elect Mirrors, Light and Rain, Interior Light pack, Flat Tyre Warning, GSM Phone Prep, Led upgrade, Illuminated speaker grills.
