Monster MotorsportVolks Autos
Results 1 to 10 of 10
    Aug 2008
    408
    Car mods dont always go to plan ;(
    Well after waiting all week to get the weekend off I thought yes ill crack on
    and fit my mfsw, having purchased a wiring loom for the inside of the wheel as well, i read as many posts as possible about coding and fitting etc, i removed the non mfsw and fitted the new mfsw along with new wiring loom to suit the wheel buttons etc, however the wheel remains functionless? the horn wont work either now? i coded it all in vagcom, i have no airbag errors either, below is a scan on vagcom if anyone can help
    aturday,26,September,2009,10:31:06:59303
    VAG-COM Version: Release 704.1
    Data version: 20071016
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 57 76
    77 7D
    VIN: WAUZZZ8P76A008244 Mileage: 43660km/27129miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    57-TV Tuner -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 BA HW: 028 101 184 7
    Component: R4 2,0L EDC 0000SG 9882
    Coding: 0000172
    Shop #: WSC 66565
    No fault code found.
    Readiness: 0 0 0 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.LBL
    Part No SW: 1K0 907 379 R HW: 1K0 907 379 R
    Component: ESP 4MOTION MK60 0102
    Coding: 0023170
    Shop #: WSC 06314
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 J HW: 8P0 820 043 J
    Component: KlimavollautomatH15 0200
    Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Coding: A58A5F26A214100000000000000000000008FE175C0200
    Shop #: WSC 06314
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.LBL
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Coding: 0071612
    Shop #: WSC 06435
    Address 16: Steering wheel Labels: 1K0-953-549.LBL
    Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
    Component: Lenksulenmodul 034 0070
    Coding: 0000012
    Shop #: WSC 06314
    Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
    Part No SW: 8P0 920 981 BX HW: 8P0 920 981 BX
    Component: KOMBIINSTR. VDO H80 0460
    Coding: 0005413
    Shop #: WSC 00847
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Coding: FD0F0FDA070101
    Shop #: WSC 00847
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:40:12
    00467 - TV Tuner (R78)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 117
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:44:19
    Address 22: AWD Labels: 1K0-907-554.LBL
    Part No: 1K0 907 554 A
    Component: HALDEX 4Motion 0105
    Coding: 0000001
    Shop #: WSC 00000
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Address 37: Navigation Labels: None
    Part No SW: 4P0 035 192 Q HW: 4P0 035 192 Q
    Component: RNS-E HIGH EU H74 0650
    Coding: 0205715
    Shop #: WSC 61379
    4 Faults Found:
    00466 - Control Module for Steering Column Electronics (J527)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:36:55
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:01
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:48:29
    00850 - Control Output Active; Radio Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:00
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.LBL
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0050
    Coding: 0000632
    Shop #: WSC 06314
    Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.3 D04 1606
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 8P0-959-433.LBL
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000403F3F8D0D489AC63300
    Shop #: WSC 00853
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 47: Sound System Labels: 8Px-035-382.LBL
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
    Part No: 8P0 959 802 H
    Coding: 0000632
    Shop #: WSC 06314
    Address 55: Xenon Range Labels: 8P0-907-357.LBL
    Part No: 8P0 907 357 C
    Component: Dynamische LWR H01 0010
    Coding: 0000002
    Shop #: WSC 06314
    Address 56: Radio Labels: None
    Coding: 0205715
    Shop #: WSC 61379
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:36:55
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:01
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:48:29
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:00
    Address 57: TV Tuner
    Cannot be reached
    Address 76: Park Assist Labels: 8P0-919-283.LBL
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0010
    Coding: 0000003
    Shop #: WSC 06314
    Address 77: Telephone
    Cannot be reached
    Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    End --------------------------------------------------------------------------------------------------
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    Quote Originally Posted by bluequattro View Post
    Coding: 0000012
    Shop #: WSC 06314
    Shop #: WSC 00847
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:40:12
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 117
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:44:19
    Coding: 0205715
    Shop #: WSC 61379
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:36:55
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:01
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:48:29
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:00
    1 Fault Found:
    000 - -
    You have a few issues here mate
    1. The steering wheel ECU is the wrong one you have 1K0 953 549 AF you need 8P0 953 549 F
    2. You may have an incorrect slip ring you need to check the part number on it
    3. You have a steering angle error which is related to the steering wheel ECU
    4. The navigation Control Module is Incorrectly Coded
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    Ok all that stuff means nothing to me! But I know on my 04 A3 I needed to change the slip ring and steering wheel ECU when upgrading to my FBMFSW.
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    Hey Bluequattro whats the chance of you having a nice leather wheel on before that your looking for a new home for.
    Aug 2008
    408
    Quote Originally Posted by jameo84 View Post
    Hi m8, are you meaning you want to buy my non mfsw from me?
    Cal
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    yeah
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    after reading that back i was not very clear.
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    Did you keep the same airbag when you changed to the mfsw, cos its the old style one i have on my 05 tdi, so think ill need to find one with the airbag included
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    These are the same problems i had last week and i was using the new/ correct slip ring and controller. I eventually got rid of most of the fault codes by coding the RNSE again but i couldn't get the steering assist to work. Eventually i took it to Audi's and it took them 2 hours and 300 to get the steering wheel to recognise the RNSE and to get the car to recognise the wheel controller. something to do with the Can gateway ....That coupled with 100 for the slipring/controller, 450 for the wheel 240 for vagcom and 350 for a laptop etc makes a very expensive volume control we live and learn
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    paddy,
    i wish id of known mate, im gutted!!!
    ive got a laptop for sale! LOL LOL
    LOTS DONE, LOTS SPENT !!!!
