EM TuningChris Nott
Results 1 to 22 of 22
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    Just got my first A3 and have a wee problem
    hey guys iv got 19" wheels with 35mm tyres, the back wheels are hitting the wells, when iv got the family in the back. whats the best way to sort this. put smaller wheels on or something with the springs.
    Aug 2008
    408
    Howdy m8, welcome to the site, are the wheels the correct offset for the car, it needs to be 45mm to 55mm offset to work ok without rubbing etc, im sure someone will be along to confirm for you. i also think theres a bolt that needs to be removed from inside the weelarch .
    cal
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    thanks the ET is 45 so i think thats okay.id like to know more about this bolt that needs removing
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    i think you should get your family to take the bus, keep the audi lookin nice and low lol, all your problems sorted
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    its her family there all giants, i made them get the train home cos the sound of my my new 19s hitting the roof made my wanna cry.
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    Ahahaha we've got a good lad here. I like it! +1 man point for you!
    Oct 2008
    133
    Remove the bolt/screw in the rear portion of the arch to bumper areas in each wheel arch. Also trim the square plastic bracket that you remove the bolt/screw from.
    What width are your tyres because a 225/19 rather than a 235/19 is desireable...
    Hope this helps.
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    thanks for that paul c ill take out the bolts.its 235s iv got on would 225 fit on the same rim.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    215/35/19s are your solution.
    Oct 2008
    133
    Quote Originally Posted by jameo84 View Post
    225/35 will fit fine. As Nate has suggested 215 will fit but personally i think this look is too stretched.
    Before buying the 225/35-19 tyres i'd go with the bolt/screw and trim the bracket back... i used a dremel type tool.
    I've attached a pic i've used before showing the bolt/screw (red) to remove and the plastic bracket (green) to trim back.
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    thanks everyone for your help iv ordered some 225's and will soon be hacking away at the bolt and bracket.
    unkle's Avatar
    Beer God
    Aug 2004
    Leics
    1,238
    Haha priceless
    Volvo V50 D5 R-Design
    jameo84's Avatar
    Sep 2009
    east kilbride
    123
    just an update all seams well with the screw removed and the bracket rubbed down. I got some 225/35/19 bridgestone runflats from the bay and imagine my surprise when two 255/35/19 tyres turned up. no use at all, they took up the width of my hall lol.
    PBA3's Avatar
    Don't hate, appreciate!
    May 2010
    So Paulo, Brasil
    35
    Nice. If some are using 235/35/19 tires and with trimming the problem goes away then with 18X8 ET42 wheel (speedline turini) fitted on 225/40/18 tires I won't really have to do that?
    Oct 2008
    Telford
    2,488
    Quote Originally Posted by PBA3 View Post
    Yeah pretty sure you will be fine
    B6 1.8T Avant s line gmbh
    20
    Wouldnt the removal of the bolt and cause a gap to be in between the fenders and bumper? It happened to my old bimmer And also, my local specialist told me that the bracket that holds the bolt couldnt be trimmed. It'll most probably leave a mighty gap in between. What tools are required to trim it back and how is it done properly? Im desperate! Running on stock suspension but i probably wasnt thinking straight as i went for 235/35/19 tires
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    the bolt only secures the archliner i belive
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    20
    That means, i can remove the bolt and trim the bracket in without any worries of a gap appearing in between the fender and bumper?
    20
    Anybody? My tires are getting cut real bad. Will the removal of the screw and trimming of the bracket cause a gap to appear?
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Quote Originally Posted by Herman View Post
    well trimming it wont leave a gap, why dont you remove screw and see what happens???
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Gryphon001's Avatar
    Jun 2009
    303
    What I found is that while 45 offset is fine the wheels will still rub quite a bit on 225 tires if the wheels are 8.5"... 8" wheels should be fine.
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    65
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    I've got the same size wheels and tyres and had 3 up in the back the other night and had a fair bit of rubbing (cue me turning the car round and heading back to get my mates car) i'm glad I found this thread... will be trying the bolt removal tip.
    Has anyone done this and lowered the car (springs/coilovers), any rubbing issues?
