Results 1 to 7 of 7
    aristides's Avatar
    Aug 2008
    Greece
    543
    Seat Belt Warning , Vag-Com
    Hello again
    Been playing with my Vag-Com the last days and i found the options for disabling-enabling the Seat Belt warning/chime.
    The thing is, since i didn`t want to deactivate it, safety first, i enabled the warning for the passenger also.
    Even though i haven`t tryed it yet with another person sitting next to me, i tried applying pressure on the seat but nothing happened.
    Is there a case that my passenger seat doesn`t support this feature?
    I tried the same thing in my sisters Golf V and it started beeping as soon as i put some pressure on the seat!
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    It's most likely that the seat doesn't have the sensor and the seatbelt socket doesn't have the interlock. I'm surprised it worked on her car though.
    The module will accept the coding but it doesn't know that it's not getting a signal.
    For example I enabled washer fluid low on my mate's Golf and straight away it told him his fluid was low (Fnar!) so he topped it up but it still said low. There was no sensor it's just the default setting in the module.
    8P2 S3
    aristides's Avatar
    Aug 2008
    Greece
    543
    Cheers for that, i guess i could now try to disable it , to see if it will work!
    FOR SALE:
    aristides's Avatar
    Aug 2008
    Greece
    543
    Ok i know tried to disable the thing but nothing happened again!!!
    What the heck am i doing wrong??
    FOR SALE:
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    What code did you put in to enable it anyway? I'm sure it doesn't come up on mine!
    From the VCDS thread:
    xxxxx?x 0 = Seatbelt Warning Inactive
    8P2 S3
    aristides's Avatar
    Aug 2008
    Greece
    543
    That one exactly.
    Tried number 5 for Driver+Passenger warning, didnt work for the passenger, then tried 0 for inactive but is still beeping without the seat belt on
    FOR SALE:
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I think mine was originally 5 for just driver's side. 0 did the trick to stop it though. In fact I've done it on quite a few cars any it's worked ok.
    Are you sure you've doing the right bit? lol
    8P2 S3
