Monster MotorsportChris Nott
Results 1 to 35 of 35
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    How much should I sell this part for ?
    just changed my centre section to the chrome set.
    I have stuck this on ebay , and people keep asking me what i will take for it.
    Any suggestions ?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=200383136407
    aristides's Avatar
    Aug 2008
    Greece
    543
    Did you change the aircon unit too?
    Is it actually plug&play or not?
    I remember a topic where NHN said it isn`t
    About the price not really sure, i guess 100 is low for sure
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    150?
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Yes i did the job my self, i was a bit nervous , but yes it was plug and play although i took my time as i had no idea what is was doing , i spoke with matt andrews THANKS MATT ! and once he told me which way to attack it from it took about an hour , as said i went very slowly.
    Before :
    AFTER :
    also added the chrome TT air vents 100 from ebay.de
    aristides's Avatar
    Aug 2008
    Greece
    543
    Excellent result mate, loving it
    What about the "AC" button? It`s the other way around in the facelift model isn`t it?
    I thought this would need a change!
    Nevermind love it!!
    FOR SALE:
    26,776
    It all depends on the year of your car, if you have a late 07 onwards 8p then the wiring etc is the same & will work ok via plugnplay, but pre late 07 is not the same, as late 07 onwards has less motors, it actually changes a motor for a cam linkage on the fan unit & also less wiring involved & the loss of a sensor which isnt needed, there are few parts different aswell but nothing major, still on my list to look at doing.
    What year/month is your car crypic cause if it doesnt use the same system then you're heading for issues with the whole climate system, trust me I've worked on this alot & tested vigorously, it will appear to work but wont or will go wrong later & its expensive to fix.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Oh , bloody hell ! March 2008 sportback HELP !
    26,776
    You should be fine with march 08, what was the part number of your old climate unit & whats the part number of your new one, elsawin has info related to this & also you can check by removing your glovebox & looking at the main fan unit behind this to see if it has the 2 blue plastic motors or the cam unit with 1 motor, if the latter then alls good.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    part number of the old one is 8PO820043AH 5PR , or ? A2C53242447 i have no idea of the new one as it is now in and i really do not want to take it all out again.
    It is from a 2009 s3 or so i was told
    How on earth do i get the glove box out to check ?
    26,776
    Undo the bolts that hold it in place namely 2 underneath, 1 inside at the back on right, 3 under the lip where the lid meets the main unit & then remove the left side plastic trim which is held in place by some clips & the door closed is hidden, just levers of & a few fingers behind & the 2 bolts at side IIRC, make sure you hold the glovebox whilst doing, can be done on your own.
    I think yours is ok tbh, but check if you want.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Sorted it s off , not sure what i am looking at , so here you go,
    [IMG][/IMG] Fingers crossed , breath held , is it ok ?
    26,776
    As you can see the orange plastic is the cam linkage & you can see the blue plug that should connect to the motor that this cam unit connects to, so yours is the newer version so alls good from what the image shows.
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Glove box removal
    open box and there's 3 screws at the top and 1 near the light
    close box and there's 2 in each corner at the bottom
    :s ignore- beaten :D
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Sorted so looks like the climate unit will be all good, glove box back on already.
    Also have learnt how to remove glove box and put back today , so was all worth it !
    I am learning slowly , but always feel slightly more comfortable checking the pros !
    Next today , how the hell to remove small on off button on sat nav , so i can spray it silver !
    Thanks guys
    26,776
    You have to remove the nav unit & take it apart, I have actually done a mod for various others to change for the newer version chrome dials, trust me its not for the faint hearted given whats involved & I dont care what others say, its delicate work given the design of the actual on/off pcb mounted knob & the selector pcb knob, if you play with them to much when modding they will go faulty & the volume control will not work properly & the selector wont select properly, also its not cheap mod.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    The selector button , just pulled of and then it clicked back into place , the on off button the very end piece is the same click on and off , but leaves the bit i want to spray on the head unit , i think the selector button would look a bit weird on its own , what do you reckon ?
    26,776
    Yes it would look weird & if you keep pulling of the selector knob & the cap of the lower knob it can make the pcb mounted dials go faulty, so you have been warned, I know the pcb dial design & its very delicate.
    evapor8's Avatar
    Jan 2009
    Guernsey, Channel Islands
    463
    That sounds like a good reason for someone clumsy like me to spend a little more on the chrome-buttoned version!
    Chris
    Car: Phantom Black A3 2.0 TFSI S-Line BLACK EDITION, 3-door, manual
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Think i will leave well alone , that is my list of mods now complete for today , You are a star !
    26,776
    Yeap very good reason, lol
    26,776
    Click on the thanks box then matey, lol.
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    oops !
    Apr 2009
    Florida (previously Liverpool)
    655
    I have a question:
    Does the light on the 'AC' button correctly indidate when the air-con is functioning, or does it light when the air-con is inactive. like the 'econ' lght does? -In other words, does it autimatically reverse it's state, or does it light up 'wrong' -if you know what I mean...
    And -my only comment about the aesthetics of it all- the 'swept-curve' button 'styling' of the old symphony2+ head unit you had matches the NEWER climate control and cupholder/hazard button styling you fitted... whereas the older, 'rectangular' button styling of the RNS-E matches the more 'rectangular' butons you took out better...
    -To my personal taste, at least.
    Those 'swept-up-at-the-edges' buttons make a nice 'smiley-face' shape, but they are matched by the same shapes on the Symphony 2+, and nowhere to be seen on the RNS navi-plus unit, which reverts to the old 'rectangle theme'.
    Keith
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    Yeah i did think that , but in the flesh they look a lot smoother and i think the old hazard button is just to in your face and has been around for years.
    The AC button only light up when turned on ,if that is what you mean.
    aristides's Avatar
    Aug 2008
    Greece
    543
    Cryptic where did you find the newer climate unit?
    And how much did you pay for it?
    Im loving the new style, steel not keen on the newer buttons, they seem a lot cheaper in quality, but the Aircon roxx!
    FOR SALE:
    aristides's Avatar
    Aug 2008
    Greece
    543
    At what price NHN?
    FOR SALE:
  28. #27
    26,776
    Quote Originally Posted by VWAddict View Post
    I have a question:
    Yeah AC button does correctly indicate on/off & the led denotes the status interms of led on for on status, all they've done is reversed the led feed & changed the button label as I checked the circuit with a meter, so effectively on old units you could rewire the circuit to change the state when pressed, personally think the econ thing was always crap as per previous audi's, just stupid imho & also to lose the off button of the climate from my last audi is a pain for sure as you have to keep holding or turning dial all the time as sometimes I like to turn it of completely in one stroke but no button, dohhhhh
    Quote Originally Posted by crypric23 View Post
    Yeah the newer buttons are actually alot better than the older ones & took week to get used to & now can see how much better visually they are over older ones, much better.
    Quote Originally Posted by aristides View Post
    I have one for sale but doesnt have heated seats, works perfectly & only got to check all the info as above stated, I actually had 2 & paid about 200 for it as they're 400 or so new, been searching for months for one, then decided to test it 1st before buying new one, so ended up with 2 without heated seats, sold 1 to guy in south america & other one is available for anyone interested.
  29. #28
    26,776
    At what price NHN?
    Preferrably what I paid as above considering the new one costs & the availability of them on ebay, not looking to profit on this just recoup if possible mate, PM for further dealings please.
  30. #29
    crypric23's Avatar
    Never satisfied
    Aug 2009
    583
    I originally bought just the air con unit from ebay on wednesday night for 125 including a chrome light switch.
    ( which i have put back on ebay )
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_500wt_1182
    As it was not the correct set up on the dials for my car , although i new this at the time and was not needed , they would not split the items.
    When i went to get them , the air con was still in the cage with the switches and they did not know how to get the air con unit out , I DID ! i was going to buy the switch section from Stoke audi anyway on Monday, so when i saw they where all still in the cage i offered them 220 for the lot settled on 250 , but i still have the cage to sell and the chrome switch. So hopefully will recoup some.
    I have as you know put my old air con and switches in the cage to get some money back , but am tempted to keep the air con just in case it all goes wrong. Although thanks to NHN , i am confident it's all good.
  31. #30
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    crypric23 - how mch do you want for the item you posted on ebay ecause i wanna by it if the price is fair .
    Many tanks,
    ANdi
  32. #31
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    I've just read this whole thread but can't distinguish between the new and old type heater matrix. Can anbody tell me if its okay to have the new style climate control unit fitted to my 06 A3, here's a pic of the heater unit behind glovebox:-
    I hope its possible
  33. #32
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    Ayone
  34. #33
    TAC
    TAC's Avatar
    3.2 V6 Burble... hmmmmmmm
    Oct 2009
    302
    Quote Originally Posted by EvolutionV View Post
    I hope its possible
    Don't think so as if you look at the earlier post by crypric and NHN and the photo of crypric's heater matrix he has the orange CAM and Blue plug which you don't have!
    Hope that helps
    Tom
    Current - A3 3.2 DSG S-Line
    Gone but not forgotten Honda S2000 GT K&N FPIK (F***ing lairy in the wet but so so much fun...)- Golf MK3 GTI 16v -Mondeo V6 24v
    FOR SALE - Indicator stalk and lower steering wheel cowling
    A3 3DR pair of rear lights in A1 condition from my 06 A3
  35. #34
    26,776
    Yeap 100% Tom, the older version has 2 motors on the fan unit flaps, where as new has 1 motor & a cam system so the single motor basically operates all the flaps, you have to have the newer cam version to fit the newer climate or remove dash & update heater system to make it work properly.
  36. #35
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    okay, thanks for your replies guys
