Badger5Sky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 66
Like Tree1Likes
Thread: 8P VCDS changes thread
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Post 8P VCDS changes thread
    As well as changing settings for retrofits such as cruise control and RNS-E there are certain settings can be changed on 8Ps with VCDS alone.
    There are far more options than I have highlighted here but most either have no use, would be detrimental or just seem to have no effect to the car.
    Feel free to add more if you know them
    If you don't know what VCDS is then have a read of THIS.
    09 - Central Electronics
    Long Coding Helper:
    Byte 0
    Bit 3 - Daytime Running Lights (Scandinavia) active - (DRLs plus tailights)
    Bit 4 - Daytime Running Lights (North America) active - (DRLs only)
    Bit 5 - Assistance Driving Light _Leaving Home active - (Note 1)
    Bit 7 - Coming Home active - (Note 1)
    Byte 3
    Bit 5 - Teardrop Wiping for Rear Window active - (Single delayed extra wipe after rear wash/wipe)
    Byte 5
    Headlight Washer Delay - (? x 50 = delay (ms)) - (Useful in the winter so you're not washing your headlights every 5 minutes)
    Byte 8
    Bit 7 - Daytime Running Light (DRL) Deactivation while Blinking active - (Turns off or dims (8P3) the DRL whilst indicating)
    Byte 17
    Bit 0 - Emergency Brake Flash Light active - (Hazards on when emergency braking)
    Bit 4 - Daytime Light via Fog Lights - (For models without DRLs)
    Bit 5 - Front Fog Lights deactivated with high beam
    Byte 22
    Bit 1 - DRLs switchable via menu - (Note 2)
    Byte 23
    Bit 1 - Advanced Comfort Menu active - (Note 2)
    17 - Instruments
    Coding:
    xxxxx?x
    0 = Seatbelt Warning Inactive
    xxxxxx?
    0 = Needles OFF and Scales Off
    1 = Needles ON and Scales Off
    2 = Needles OFF and Scales ON
    3 = Needles ON and Scales ON (Dimming active)
    4 = Needles ON and Scales ON
    44 - Steering Assist
    Adaptation:
    Channel 001 - Steering Assistance - (For some models before 2008)
    46 - Central Convenience
    Long Coding Helper:
    Byte 0
    Bit 0 - Selective Central Locking (Single Door Opening)
    Bit 3 - Auto-Unlock (Unlocking after removing key from ignition)
    Bit 4 - Auto Lock (Automatic locking from 15Km/h)
    Byte 5
    Bit 6 - Comfort Function automatic closure - (The button doesn't need to be held down to close the windows/sunroof)
    Bit 7 - Power Windows/Sunroof disabled after door opening - (Note 3)
    Byte 6
    Bit 2 - Comfort opening Power Windows via Remote Control
    Bit 5 - Comfort closing Power Windows via Remote Control
    Byte 7
    Bit 5 - Comfort closing Sunroof via Remote Control
    Byte 8
    Bit 0 - Unlocking Confirmation (Blink) via Door Locks
    Bit 1 - Unlocking Confirmation (Horn) via Door Locks (Note 4)
    Bit 2 - Unlocking Confirmation (Blink) via Remote Control
    Bit 3 - Unlocking Confirmation (Horn) via Remote Control
    Bit 7 - Horn Configuration Blocked - (Deselect to make changes)
    Byte 9
    Bit 0 - Locking Confirmation (Blink) via Door Locks
    Bit 1 - Locking Confirmation (Horn) via Door Locks
    Bit 2 - Locking Confirmation (Blink) via Remote Control
    Bit 3 - Locking Confirmation (Horn) via Remote Control
    Byte 10
    Bit 6 - Synchronised Mirror Adjustment - (Control both with driver setting and passenger only on passenger)
    Bit 7 - Mirror Lowering with Reverse Gear (Only with memory seats) - (So far no one has done it)
    Notes
    Note 1 - CH and LH lights can be enabled on models with Bi-Xenons with just coding. For other models read THIS or for models with LED DRLs read THIS.
    Note 2 - Advanced Comfort Menu allows certain settings to be changed via the DIS. These are as follows:
    -Ext Lights
    -Daytime Lights - (DRLs On/Off)
    -Coming Home - (Time delay 0 to 60 seconds in 5 second increments)
    -Leaving Home - (On/Off only. Delay can be adjusted in adaptations. Default 30 seconds)
    -Wipers
    -Front - (Service position On/Off)
    -Rear - (Automatic on in Reverse On/Off)
    Note 3 - This function works in reverse on my car. With this selected I can still open and close my windows once the door has been opened.
    Note 4 - Enables alarm beeps when unlocking and/or locking the car. http://www.youtube.com/watch?v=Ug81apPh3Jc
    Useful Links
    http://en.openobd.org/audi/a3_8p.htm
    http://oooo-a3.blogspot.com/
    http://wiki.ross-tech.com/index.php/Main_Page
    Westy likes this.
    8P2 S3
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    562
    Quote Originally Posted by Staz View Post
    Bit 7 - Mirror Lowering with Reverse Gear (Only with memory seats) - (So far no one has done it without)
    Is this something else I'm learning today? - Memory seats??? I didn't think the S3\A3 had these?
    Wicked write up by the way. Good work.
    You can take the boy out of Essex but not Essex out of the boy...
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    562
    I have found my answer...
    Getting exterior mirrors to tilt (dip) when in reverse
    And sadly its a no...
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    You're right, I don't know if there are memory seats on 8Ps actually it certainly wasn't on my options list.
    I was thinking about linking to that thread funnily enough
    8P2 S3
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I'm stickying this just for a week so that people know it's here
    8P2 S3
    I have an electrically controlled drivers seat on my A3. When I enquired about having a seat or seats with memory settings I was told these were not available on the A3 range.
    Dave R (h5djr)
    KRL
    KRL's Avatar
    Jul 2007
    523
    I've got folding wing mirrors on my S3. Does anybody know if these can be programmed to fold on ignition off and unfold on ignition on?
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    They can't be programmed that way no mate.
    I have designed a circuit that does it for my folding mirrors retrofit but I am not sure if I'm going to build it yet.
    8P2 S3
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    In case you didn't know there's a members with VCDS thread in the VCDS forum:
    http://audi-sport.net/vb/showthread.php?t=57430
    I thought maybe we could generate our own list in 8P in this thread as more and more people are asking for help here. Thoughts anyone?
    EDIT: There's a map here: ***VCDS Users Map***
    8P2 S3
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    Didnt Nigel design the circuit, hes been discussing the cicuit for as long as I can remember. I started to look at it but the problems with burning the motors out etc was the issue, im sure he resolved the issue and got it working, Im just waiting for him to sent me the completed circuit pcb
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by mattandrew View Post
    Nigel designed a cicuit yeah but he said it didn't work. I designed a circuit from scratch using Multisim and on there it works. It can be fitted with variable resistors to fine tune the timing to prevent to motor burn out.
    8P2 S3
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Should this not be in the VCDS thread ?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    He told me on MSN a few weeks back that he designed one circuit a while ago that worked ok but then he did another (can't remember why) that didn't work. I may have been mistaken though.
    Either way I have done a completely different one off my own back but I have been trying to source new modules before going ahead and building it.
    8P2 S3
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Staz
    A list of members with Vagcom and 8P experience can only be helpful as long as they know what they are doing ! just my 1p worth....
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    If someone doesn't know what they're doing then they shouldn't post themselves as people who can help!
    8P2 S3
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Yea ok but i have a lead and a laptop that people could use but i dont know how to do "everything" with it.
    Maybe i will just shut up again. everyone here is just soooo negative !
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Right, so then you say "Hi I'm Paddy, I have a laptop and lead but I don't know how to use it. If you do then you're welcome to have a go."
    8P2 S3
    In connection with the things that can be changed using VCDS, I've tried to change the item in 46 Central Conv controller Byte 5 Bit 7 that allows the power windows to remain working even after the ignition has been turned off. I have tried it with the box ticked in the Long Code Helper and Unticked (VCDS 908) and it does not seem to make any difference. They will still not work once the ignition has been turned off and the drivers door opened.
    Has anyone tried this and got it to work?
    Dave R (h5djr)
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by h5djr View Post
    Yes Dave if I have this option deselected the windows still work until I open the door. The auto function is disabled though.
    With the option ticked the window works with the door open but once it's closed again they're disabled.
    8P2 S3
    I think I was trying to get something that is probably not possible. I have it set now so that when I turn the ignition off and open the door, I can still close the window.
    What I thought was possible, but clearly isn't, was to turn the ignition off and get out of the car using the drivers door. Close the door and for my passenger to then still be able to open a window.
    Dave R (h5djr)
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Aha no I don't think that's possible mate.
    8P2 S3
    heyadamhey's Avatar
    May 2009
    Joburg, South Africa
    126
    On the wing mirrors topic - is it possible to control them at all with VCDS?
    Reason I ask, is 'cause my brother's 325ti used to dip the wing mirrors when in reverse, so you could see kerbs etc better.
    cool function...
    Akoya TDI 140, 18" S4 Rims, VCDS, H&R
    Getting Hybrid treatment
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by heyadamhey View Post
    cool function...
    There's an option there for that very function but the label says "Only with memory seats" and it doesn't work anyway. Many have been asking about this but no one has got it to work.
    8P2 S3
    27,126
    Thing is & its been discussed many times, the MK5 golf has this option, aswell as dual mirror movement IIRC, its ridiculous that audi is the more premium brand but we get lesser features than the MK5 which is the 8P equal chassis as such.
    & as Staz says you wont get this on the 8P anyway, you could probably get it working with seats from another chassis & mirror modules as it relies on these as the A3/A4/A6 range of certain chassis shared mirror parts so not impossible, but its whether the canbus would allow them to be recognised on the 8P.
    Personally I'd rather get the mrs her own car, lol
    pns2007's Avatar
    Nov 2008
    627
    Nigel,
    For info, I have enabled the wing mirror dip when ptting car into reverse. I have also enabled the needle sweep.
    Can any modules/parts be used from an A4 in the A3? If anyone knows the answer, you will
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    27,126
    You little shyte, audi have added that to the B8 aswell then, they're gits huh as mk5 seemed to have them all.
    You mean B8 onto the 8P mate?
  28. #27
    pns2007's Avatar
    Nov 2008
    627
    Yes lol
  29. #28
    dramirez's Avatar
    Feb 2009
    Mexico
    27
    Question
    Quote Originally Posted by pns2007 View Post
    Needle sweep like the S4 on our A3 8P, HOW???
  30. #29
    27,126
    Sorry Ramirez its not possible on the A3
  31. #30
    8pj
    Dec 2008
    6
    A bit late but anyway: Yes it is possible, but only on the S3
    Quote Originally Posted by dramirez View Post
  32. #31
    267
    Quote Originally Posted by 8pj View Post
    8pj - I have a 2007 S3, can I activate the needle sweep via VCDS?
    Thanks.
  33. #32
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    just found an answer i already knew but forgot, cheers for saving the raking
    @onespoke sadly id doubt it unless youre a very late one think its 08 on, tbh its a bit rubbis on the s3's its just a quick flick rather than a sweep
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
  34. #33
    Lima's Avatar
    AUSmotive.com
    Apr 2009
    Canberra, Australia
    395
    Every time I hop in my car and my iPhone connects via Bluetooth there is a chime to indicate the phone has paired successfully. Invariably this chime sounds in the middle of a news segment, cricket score, whatever and I want to know if it is possible to disable the chime via VCDS.
    AUSmotive.com // AUSringers.com
    AUDI: MY10 S3 (8P3) / Nav+AMI / Sunroof / Blackout Grille / RS6 FBMFSW / PSS10s / Milltek TBE / APR HPFP / APR Stage 2+ tune
  35. #34
    TAC
    TAC's Avatar
    3.2 V6 Burble... hmmmmmmm
    Oct 2009
    302
    Quote Originally Posted by Lima View Post
    I too would like to know if it is possible to get rid of this annoying chime?!?!?! I'm sure NHN will have the answer?!?!
    Current - A3 3.2 DSG S-Line
    Gone but not forgotten Honda S2000 GT K&N FPIK (F***ing lairy in the wet but so so much fun...)- Golf MK3 GTI 16v -Mondeo V6 24v
    FOR SALE - Indicator stalk and lower steering wheel cowling
    A3 3DR pair of rear lights in A1 condition from my 06 A3
  36. #35
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Re: 8P VCDS changes thread
    You can't disable the chime but you can reduce the volume. There's a link in the FAQs thread
    8P2 S3
  37. #36
    27,126
    Wish I did Tom, its a real pita tbh, but as Leon says you can lower this volume of the tone by pressing the SDS button on your MFSW, saying help & whilst she is talking all the ****** just lower the volume & this should retain for the BT connection tone aswell.
  38. #37
    Oct 2010
    69
    In the original post where it says 'Bit 0' (for example) does this mean the first digit (0 or 1) in the binary code, counting from left to right?
    So 'Bit 7' is actually the last digit? (What I would call 'Bit 8', as if I remember my GCSE IT correctly there's 8 bits in a byte)
  39. #38
    27,126
    If you have say a long coding page in front of you in vcds, you can see at the top it shows the bytes in hex/dec form going from left to right starting from byte 00, then below it shows the bits with tick boxes, being bit 0 is the top box, going from top to bottom.
  40. #39
    Oct 2010
    69
    Thanks for the reply, but there isn't tick boxes everytime is there?
    For example see the pic below. So according to the guide above, 'Bit 7' in Byte 0 is a 1. Is that right? It's just a bit confusing counting the bits when coding, and I want to make sure I'm doing it right, and changing the right bits.
  41. #40
    27,126
    Whats version of vcds are you using?
