AH FabricationsChris Nott
Results 1 to 14 of 14
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    Talking Pro Alloy Intercooler
    Monday I ventured up 70 miles to Pro-Alloy to get my intercooler fitted and Forge Throttle body pipe.
    First off I they gave me a tour of the workshop and build/design processes. I didnt actually realise what they did from a motorsport perspective. Basically they have their fingers in a lot of pies, but some big recent jobs have been with Ford, building the upgraded IC for the ST that is now being installed by Ford at the factory when the customer upgrades the IC (its a build option) and they also do the Focus RS IC. Other than that they work on a lot of Lotus kits, Vauxhall, Ford, VW etc.... They also do fuel tanks and catch cans etc. There was some Noble and Jag pieces about too. Everything else was special pieces for customers. Ive got to say I was impressed with the quality of the work.
    Here is the kit:
    I then got to see the build of my IC, they took me through the design and how they got to that being the better option. Basically, they believed the Audi OEM design was good (size etc) but the flow was poor with large areas of turbulence. They wanted to keep it quite stealth so they have only made the actual IC a little larger, and 1cm thicker with larger a surface area and the core is much bigger, they showed me how and at the time it all made sense. Everything about the IC build was top dog! Despite the fact it will never be seen behind the bumper, it looks great, every weld is perfect and finished off really well with a brushed alloy finish.
    Down to the install, I left the car there and headed off to town for some lunch and a walk about. They basically needed to perfect the install notes from the initial install on Tobys.
    Everything went to plan and the car was ready at 4pm, they have changed the throttle body pipe for me too. The air con gas was back in and I took the car for a quick drive. It felt a little different, wasnt sure what but I didnt give it big beans! So I got back, we checked the water levels etc and everything was good, So I left and went on my way :D.
    First thing I noticed, the car seemed to idle better and when slowing down it coasted better whilst in gear, a lot smoother and easier, like when you have the car mapped. As I got to the motorway and pulling on I slowed and dropped it into 4th and hoofed it! The best way of explaining it is, where before the torque band used to be at the max mid 3.5K it now starts building boost sooner by about 300rpm and holds on to that a lot further up the rev range very strong, (probably increased the big surge by about or mare than 500rpm). The restriction after that initial sure has reduced and the torque band is a little more aggressive, a lot stronger further up the rev range as well as down below. Now Im not sure what the IC has done or the throttle body pipe, but whatever it is, its been well worth it! To top it all off, the car feels a lot more aerodynamic, I know that sounds silly, but thats exactly how it feels. Well impressed with the transformation!
    Im going to run some data logs at some point and let you know the temp differences. Not stuck it on the dyno yet, Id quite like to as I have done so throughout the tuning process, so watch this space, but on the road it feels very lively!
    Only bad thing.... Although it hasnt slipped yet, my clutch is starting to feel a little sloppy.... It may just be me but well have to see how it goes!
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    slim40's Avatar
    Aug 2009
    Cambs
    38
    Excellent write-up and pics!
    Dare I ask the price of such an item?
    cheers
    Slim
    S3 8P remapped to 308bhp/395Nm, all the toys, but no buckets
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Nice write up mate. What sort of gains are you expecting or is it not about peak performance but all through the range?
    8P2 S3
    Lambchop's Avatar
    Aug 2009
    Johannesburg , South Africa
    15
    WOW Awesome write up . That IC looks the part
    Iv just been on the Pro Alloy website and cant see this item for sale at the moment
    Is it available to the public ?
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    The item was very reasonably priced if you ask me, very similar to the Forge, but after some research in inlet temps and the fact I didn't need to chop away any part of the bumper I wanted to go the Pro-Alloy way. It is a 4-5 hour install and they need to de-gas the air con but they obviously re-gas it. I would also advise while they are in there to fit the forge throttle body while they are in there as it's a nighmare to fit with the front end installed.
    They originally fitted the kit to Toby's car, they have now gone through the fitting guide with mine and I believe they are happy to start working on getting a kit available to the public, either to install in house, or sent out to whoever for install.
    TBH, I'm not expecting the power to have gone up much, if at all. Granted it feels different and the torque band is bigger/stronger but my last dyno reading was 372bhp with 360lbft, I don't really think I can get much more out of the K04 turbo.... Maybe I can, I don't know until I stick it on the dyno.
    But the engine response and the way it drives is very unrestricted now.
    I'm sure Pro-Alloy will be able to get it onto the market very soon if you asked nicely
    Lambchop's Avatar
    Aug 2009
    15
    Awesome . Im going to ask Pro Alloy very nicely .
    Here in SA were going into Summer so I need all the help I can get
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    On June 24th i emailed AMD and Jabbasport who both told me the price was 670 plus VAT so total of 770 at 15% VAT. It`s a very nice intercooler and i would always get Proalloy stuff over Forge made things if possible as they are always designed for max performance not style and for the DIY fitting market like Forge stuff is.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    181
    I think I might go for one of these too!I called pro-alloy yesterday and they told me it would be 590 + vat and it would be about 4 weeks before it would be ready.
    gone: 2008 S3 sprint blue, buckets, optics, go-faster mods.
    b19ctr's Avatar
    The King of Cannock
    Aug 2007
    Cannock
    634
    What have you done with your old intercooler? As i know that the TDI can be upgraded to an S3 intercooler
    Air, OZ, Tarrox, on a TDI
    Aug 2009
    Darvel, scotland
    135
    Spot on m8 this is the one am goin for too!! Pro alloy is a big name in the ford world too
    GIAC pump & race map WITH CONTROLER, VF ITAKE ,AUTOTECH HPFP,MV DOWNPIPE & MILTEK CAT BK,RS4 REG,UPRATED OEM DV, CUSTOM ENGINE COVER, BOOST GAUGE & POD, H&R SPRINGS, OEM BLACK WHEELS, FORGE CATCH TANK AND WASHER BOTTLE ,RNS-E SAT NAV BLUETOOTH,FLAT BOTTOM, BUCKETS,PRE-FACE TAILLIGHTS TINTS
    KRL
    KRL's Avatar
    Jul 2007
    523
    Is there any more information available about this IC? - Length, Height, depth, capacity, pressure drop etc?
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    I would just like to say that Pro Alloy make some quality products however ...Forge is in the works , it will run with or with out the twintercooler so stay tuned ;-)
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    Whilst we make our intercoolers for direct bolt up and ease of fitment I can assure you it will do the job of any of the competitors , all are tried and tested , the twintercooler design will perform with the original intercooler as well as anything on the market , the development of the new Forge alloy FMIC to run with the Twintercooler will simply take it to another level
    Quote Originally Posted by devonmikeyboy View Post
    Oct 2008
    888
    "New Forge alloy FMIC" ? Whats this then.
