Badger5JMB Retrofits
Results 1 to 12 of 12
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    2.0tdi bkd vibrations in the cabin on idle
    Hi,
    Has anyone experienced the car vibrating on idle, which is detectable in the cabin, when the engine has warmed up? After driving for 15-20 minutes, when I stop on traffic lights, I can feel the engine vibrating, that does not happen when the engine is cold.
    I am sure this was mentioned before, but not being able to find it, I'll ask.
    Thanks.
    VCDS USER
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Dodgey flywheel wheel which is a common fault in most of the TDI range throughout VAG
    Can be replaced but at a cost
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Could be the flywheel as mentioned but i would be surprised if it is in this case as the DMF flywheel doesn`t warm up so would vibrate all the time not just when the engine is hot.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Quote Originally Posted by devonmikeyboy View Post
    That's what I was thinking, as when the engine is cold, there is no symptoms.
    Maybe EGR valve or something ?
    VCDS USER
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    if you put the AC on, does it go away when idlign rough or not idle as rough.
    If thats the case, it will be your timing torsion.
    Mine had exactly the sae symptoms as yours and adjusting the timing sorted it.
    There's a vid floating about by me under the thread rough idle demonstrating this
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Saw the video kaz, it's not like what used to happened to your car.
    Putting the AC on does not make a difference.
    VCDS USER
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    My idling was intermittant - some days it would be bad, some not so bad, some terrible
    usually pointing down a hill it went away completely!
    kaz219's Avatar
    Jun 2008
    1,796
    more than likely dmf mate...
    Vagcom'd too
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I'm planning a remap soon, just wondering if I should go ahead with it or replace the dmf before... ?
    VCDS USER
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    remap will not affect the DMF but will cost a bit - if you are replacing the DMF, I would consider replacing the clutch too
    Feb 2007
    1,257
    Quote Originally Posted by Boydie View Post
    Of coarse a remap will affect a DMF. With a remap the car will be making more bhp and torque. The torque goes through the DMF and clutch putting a DMF mechanism under more pressure and therefore more likely to fail same as a remap will make a slipping clutch worse for the same reason.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I guess I'll see how it works after the remap and then decide what to do with it . Anyone knows the approximate cost of dmf & clutch along with the cost of the replacement?
    VCDS USER
