Chris NottMonster Motorsport
Results 1 to 12 of 12
Thread: Satnav install
    May 2009
    29
    Satnav install
    i have an a3 53 shape it as a single slot cd ive got hold off a s3 satnav
    so to install it an i right to think i just chane the air con unit and cup holder is it that simple or is it harder than that
    Mar 2008
    Bradford, WY
    788
    you need a new double DIN cage to house the RNS-E new facia surrounds and a double din air controller unit (although you can cut the exiting one to shape if your careful) and some VAG-COM coding
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Apr 2009
    Florida (previously Liverpool)
    655
    ...and some wiring.
    And either a sharkfin antenna or a clamp-on FAKRA antenna.
    Also the switch panel around the cup holder, plus new switches etc.
    Keith
    Aug 2005
    London
    263
    It sounds a lot but actually all the parts can be had off ebay or a breaker or even Audi at reasonable cost. I think I paid 150 for all the parts, including a replacement climate control unit.
    I did it last weekend and although it does take some time, it isn't a very technical job to do.
    May 2009
    29
    thanks for your help were will i find somone to do the vag
    heliflyer's Avatar
    Jan 2009
    Chesterfield
    151
    Have a look in the vag com page theres a sticky to see if theres anyone who will do it your area , or if you want to buy one i believe NHN sells them at a good price give him a shout cheers Ian
    A3 2.0T S Line Quattro
    Apr 2006
    england
    754
    would the sat nav work without the vag coding??
    Aug 2005
    London
    263
    Yep but you won't have the info displayed in the DIS
    Apr 2006
    england
    754
    Quote Originally Posted by davej_anderson View Post
    i guy local to me has a diagnositic machine, might try him for coding when i do the rns e install, have you got the codes to hand of what needs to be changed to make the rns e work well?
    Aug 2005
    London
    263
    Sorry mate, not to hand, do a search, including the RossTech wiki page.
    As the coding will be specific to the options on your car there isn't a general set of codes to use.
    I'm still to get mine coded...can anyone help with Vag Com in S London?
    Apr 2006
    england
    754
    Thumbs up
    no problems mate, thanks anyway
