EM TuningJMB Retrofits
    locost47's Avatar
    Aug 2009
    Lurgan
    129
    How to fit lowering Springs on an A3
    Hi everyone, I have got a set of H&R's 35mm springs and am going to have a go a fitting them today as the garage who was supposed to be doing the job let me down. I have fitted springs before on my previous cars but would appreciate a link/advice on the best way to do this on my A3. I have searched through the Forum for the 30mins and couldnt find what I was looking for. Thanks for your help
    Tommy's Avatar
    Makinen...ha
    Jan 2009
    Sheffield
    443
    i think you need spring compressors mate?
    Not entirely sure though
    Oct 2008
    Telford
    2,488
    They are no different to do than any other car mate, you will need compressors though. only fiddly bit is removing all the plastic crap in the engine bay to get to the top mounts. Not hard, just fiddly!
    B6 1.8T Avant s line gmbh
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    When I did my first A3 I found the fronts quite tricky!. The hardest part was removing the strut from the hub as it's a tight fit, you can get a spreader tool from VW for about 7 I believe but I can't remember the part number!. You'll also need spring compressors to strip the front struts and some means of undoing the nut on top probably a swan neck spanner but I have used a socket and mole grips with an allen key through the middle before!
    The rears are a doddle.
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    locost47's Avatar
    Aug 2009
    Lurgan
    129
    Thanks for the help, much appreciated I got a bit trigger happy and decided to have a go fitting them before the Seat Cupra link was posted and in hindsight I seem to have done it the longer way by taking out the complete hub, strut assembly to do the spring change, but its all done now so I can chill out and admire my handywork..lol Thanks again
