Results 1 to 8 of 8
    Mar 2008
    53
    Concert to Symphony II+ swapping over?
    Hi,
    I have the 2007 Concert basic cd player in my 2007 s3 and am wanting to swap to a Symphony II+ and was wondering if this is a straight swap? will I need any additional wires or does anything need VAg on it?
    Any help much appreciated, I assume as its the single to 6 cd thats the only realy change that its a fairly easy swap?
    Cheers again
    Apr 2009
    Florida (previously Liverpool)
    655
    Not a straight swap.
    The Concert has ISO connectors, whereas both the Concert 2+ and Symphony 2+ use the Quadlock.
    'Concert 2+' to 'Symphony 2+' is the 'fairly easy swap' of which you speak... but if you have the 'Concert 2' then you'll need an adaptor, and THEN it's easy enough.
    If you have the SINGLE-DIN version, then things get really annoying!
    Mar 2008
    53
    Its this one here, hopefully the easy option of the two as likely hod is I need to get the symphony II+ decoded so this is a lot of effort if its not the easy switch ha ha
    Apr 2009
    655
    Plug and play mate.
    Though you may need the options coded with VAG-COM, depending on how the replacement unit is coded to begin with...
    Keith
    Mar 2008
    53
    Quote Originally Posted by VWAddict View Post
    Plug and play mate.
    Keith
    Thats a relief cheers for that Addict, I think its going to have to be fully coded all round really as buying it cheapish and its got no code with it, these guys can help for a price,
    http://cgi.ebay.co.uk/Audi-Radio-Cod...d=p3286.c0.m14
    Bought some removal keys and will masking tape it up good, then should be ready to swap. Do I just remove the old one, do I need to do anything? I searched round on here and it mentioned transportation mode or something....?
    Thanks for your help
    Apr 2009
    655
    I've even made my own 'keys' before now... I got a couple of hanging file folders, and pulled out the metal 'flat-rods' which are inside, then cut them at about a 30 angle with a pair of cutters, and filed them so there are no sharp edges. -then I just slip them in with the 'pointy-edge' outermost, then once they're all the way in, I 'push outwards' slightly, and remove the head unit, inching outward one side at a time.
    Never heard of a decoding service before... (being a Scouser, you'd expect me to know ALL about that sort of thing! )
    Keith
    Jun 2003
    World of my own
    9,813
    This article is pretty comprehensive:
    http://forums.audiworld.com/showthread.php?t=2017312
    Alex Turner
    Apr 2009
    655
    Is this the right thing also?
    -It's over there in the UK, and looks cheaper than the kufatec one...
    http://cgi.ebay.co.uk/Audi-RNS-E-RNS...mZ150369219992
    Keith
