DaveA3-TDI
Have been checking the engine bay of my 2.0 tdi today and there is a large pipe in at the front of the engine in the middle which comes up from the bottom and into the inlet manifold which has the egr bolted onto the side of it. Where the pipe connects it has some kind of retaining clip which I have ensured is fitted correctly but have noticed that oil has been leaking from the connection and has been running down the back of the pipe. Is this normal ? It seems to be only a small amount and not puddles. When I took it apart and reconnected it I noticed that there was oil inside the pipe and there was a rubber seal around the edge, could this need replacing ?
thanks in advance
thanks in advance
