Chris NottBadger5
Page 3 of 26 FirstFirst 1234567891013 ... LastLast
Results 81 to 120 of 1016
  1. #81
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I have the ElsaWin factory repair manual.
  3. #82
    Jun 2006
    Durham, England
    171
    not received anything yet mate?
    did you send it to my email address?
  4. #83
    edition's Avatar
    Nov 2007
    1,417
    How big is the file Paddy?
    Fancy sharing
  5. #84
    Jun 2006
    Durham, England
    171
    got it now mate cheers. no pics come through but i think there is enough for me to go on cheers!
  6. #85
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Coxy
    If you need anything else i will just copy it onto a word doc and send it, then you will get the pics
    Fuel pump relay OK (position -R3- in electronics box in engine compartment)
  7. #86
    Jun 2006
    Durham, England
    171
    thats spot on mate cheers! luckily i have a spare relay plate too from the scrapper audi I piladged will nick the fuel pump relay off that
  8. #87
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Edition
    The file is 6gb !!!
  9. #88
    edition's Avatar
    Nov 2007
    1,417
    Ah...... maybe not then!
  10. #89
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    anything i can help with just pm me an e-mail address and i will send you the relevant page/s mate.
  11. #90
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    This is where i got it. Takes a few hours to download but it is good. Its basically what the dealers have...
    http://www.whichmanuals.com/Cars/Aud...9cb132045415f3
  12. #91
    Jun 2006
    Durham, England
    171
    development. I have swapped the fuel pump ecu relay and the problem has been reduced quite a bit. its still a little fluffy, but how can it reduce the problem but not clear it? what are the odds of having 2 faulty relays?
    I am wondering if this is a bad earth fault?
  13. #92
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Don't suppose you have disturbed a corroded pin socket on the relay board. by swapping the relays you might have got a better contact but not a perfect one ??
  14. #93
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    I wonder if changing the relay has reset the ecu?
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
  15. #94
    Jun 2006
    Durham, England
    171
    nah i doubt that will happen, no power has been cut to the ecu, and even if it did that wouldnt reset the ecu immediately.
    and I have vag commed the car and reset the ecu before and it never made that much difference.
    hmmm, I wonder if there is a fault with the relay board?
  16. #95
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    I just can't see it being anything to do with the fuel pump relay, surely all that does is turn the pump on/off, it won't control the actual fueling.
    Previous
    2008 Red S3
  17. #96
    Jun 2006
    Durham, England
    171
    16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    Possible Symptoms
    Power Loss
    Possible Causes
    Camshaft Adjustment Valve 1 (N205) faulty
    Fuel Pump Relay (J17) faulty
    Possible Solutions
    Check Camshaft Adjustment Valve 1 (N205)
    Check Fuel Pump Relay (J17)
    (intermittent)
    there it is - fuel pump relay
  18. #97
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Maybe it is then, but why would it be always at the same point in the revs.
    It could be that my chain rattle is a seperate issue but I don't think so, it's too closely connected to the misfire that I'm getting.
    I may give the garage a ring tomorrow to see if they've diagnosed it yet, although I've been told by my better half to stop poking my nose in
    Previous
    2008 Red S3
  19. #98
    Jun 2006
    Durham, England
    171
    Yeah chase them up see what they have to say
    Who knows what effect a dodgey fuel pump relay will have. It could be having a spiking effect on the vvt actuator, or it could even be supplying power to the VVT solonoids or something.
    I will see if my fuel economy improves any.
    Paddy - can you find the location of the camshaft Adjustment Valve 1 I am assuming its the solenoid. bet its a rocker cover and side plate off job.
  20. #99
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    The Camshaft afjustment valve (N205) is number 3, That's already been changed on mine and yes you have to remove the cover to get at the fixing bolts
    Previous
    2008 Red S3
  21. #100
    Jun 2006
    Durham, England
    171
    you know this has to be an electrical fault!
  22. #101
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I am beginning to think this could be different faults we are chasing.
    If i drive at exactly 2k in 6th, my car feels like i am intermittently lifting my foot off the gas for maybe 1/2 second every 2-3 seconds. If i could dab the brakes really quickly that would be about it. At first i thought it was right on the point of changing gear . Problem has passed by 2300 rpm. It is more noticeable obviously up hill, under load which is why i doubt its chains on mine, especially as i have only just hit 40k miles and it started doing it shortly after its 36k long service.
    What you guys have seems a little more extreme ??
    I agree with coxy that its electrical on mine. I had something similer on a bike once and i traced it to a plug lead shorting out intermitantly under load..............after i had changed the coils and the ECU
  23. #102
    Jun 2006
    Durham, England
    171
    Thumbs up
    Well I drove to work today with no issues to speak off. The problem manifested it self on my car most if i had a very small throttle opening, from 1500rpm through to about 2500rpm where the car would feel exactly like paddy says, slightly on and off the throttle - like minor driveline shunt.
    I actually think i could feel this issue right up past 3000rpm, but its masked more by the speed of the engine.
    Didnt get that at all this morning, and the car holds 2000rpm now, although the throttle can still be a little fluffy at these openings I suspect I have now sorted my problem. I might invest in a brand new fuel pump relay, and do a full ecu reset and throttle adaptation again.
    Will let you know how I get on.
    Ian
    edit: point to note, the relay I took off had 'kracker' written on the side of it, and was white, where as the relay i put in from my spare board looked like a proper vw one with the big number on the side of it.
  24. #103
    edition's Avatar
    Nov 2007
    1,417
    Sorry Ian, what have you done that has sorted it?
    The oil change? or have you done something electrical as well?
  25. #104
    Jun 2006
    Durham, England
    171
    I swapped the fuel pump relay.
  26. #105
    Hammer it!
    Sep 2009
    40
    Quote Originally Posted by 3.2 Ju View Post
    Exactly how mine was when I picked it up. Does your's have a chain rattle at all?
    Although it feels like a gearchange, I don't believe it's related, I just think there are more dsg 3.2's than manuals!
    I'd love a mini meet from anybody local to me to compare the problem, Im in Bradford but don't mind a bit of travelling.
    Mines actually MUCH worse now than when I got it. I'm also hoping to get it in this week once and for all and it IS chain related on mine. I have the following fault codes at the moment:-
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 008 - Implausible Signal - Intermittent
    16398 - Bank 1: Camshaft B (Exhaust): Retard Setpoint not Reached (Over-Advanced)
    P0014 - 008 - Implausible Signal - Intermittent
    Audi want to strip out the gearbox and open it up to see whats going on, but i've read loads of stuff on the internet about 3.2 chain problems from tensioners to chains to oil pressure and problems related to the variable service interval and I reckon it could be that the tensioner is not adjusting properly. I've been monitoring the chain for lengthening from day one and it's well within tolerance at 2 and 1 (out of tolerance is over 8) and it's never really moved from that.
    Julian
    Hi live near Bingley if you want to come and have a listen, Mines a manual and find idle sometimes affected by fuel. ticks over better on 98 ron fuel rather than normal unleaded where the tach needle wobbles abit. Apart from that runs well.
    Simon.....
  27. #106
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Hi there Simon and thanks for the offer. The cars in at the dealers at the moment and it might come back sorted out...... lol!!.
    I rang them today and surprise surprise, it's not been worked on yet. Apparently they've listened to the engine and decided the gearbox has got to come out before they can find out what is going on with the rattle. I asked him if the misfire was related and he said.....................Oh has it got a misfire!. Not exactly confidence inspiring is it!
    I expect it'll be in there all next week.
    How's the car Ian, fingers crossed it really was that simple!
    Previous
    2008 Red S3
  28. #107
    Jun 2006
    Durham, England
    171
    spoke too soon, it appears to be back...hmmm I wonder if this relay is knackered too, as it definately ran a hell of a lot better when i plugged it in.
    Going to strip the relay down and spray it with contact cleaner, and see if it makes it any better. If it does, then its new relay time!
    Ian
  29. #108
    edition's Avatar
    Nov 2007
    1,417
    Let us know how you get on.
  30. #109
    Hammer it!
    Sep 2009
    40
    Tell me it's not Bradford Audi?
  31. #110
    edition's Avatar
    Nov 2007
    1,417
    Can't be worse than Harrogate!
  32. #111
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Or Guildford
  33. #112
    edition's Avatar
    Nov 2007
    1,417
    Or Leeds (sales)
  34. #113
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Quote Originally Posted by edition View Post
    DOH!!!!
    Previous
    2008 Red S3
  35. #114
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Quote Originally Posted by paddy View Post
    If you take my chain noise out of the equation, that's how mine is so I do think they are all the same problem. It's too much of a coincedence that we all have very similar symptoms.
    Previous
    2008 Red S3
  36. #115
    edition's Avatar
    Nov 2007
    1,417
    It at Harrogate then?
  37. #116
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,204
    Never set foot in the place myself. I've always used either Huddersfield or Wakefield although I've noticed there all part of the same Syntner group!
    Previous
    2008 Red S3
  38. #117
    Jun 2006
    Durham, England
    171
    so i went and bought a brand new fuel pump relay, no joy.
    so, its not the maf, cam sensors, fuel pump relay as I have replaced those. Its not the vvt actuator as 3.2 Ju has replaced those. Not sure what else there is?!
    Has anyone with this problem actually had their cars remapped? It would seem every who has this problem has always had it from day 1? Could be just a batch of bad maps or something. I have a spare ecu that i am going to try see if that has an affect. Other than that we are looking either earth/wiring faults, or a problem with the oilways in the vvt?
    Its a head scratcher. I honestly dont think its the chains as it wouldnt pull so well if they were all stretched and knackered.
  39. #118
    edition's Avatar
    Nov 2007
    1,417
    Huddersfield were good when I bought mine from them. The service has always been good also.
    I went to Harrogate as they are my local dealers and was getting abit annoyiong drivng to Huddersfield.
    Harrogate cocked up big time on some paintwork and were found to be utterly useless in that respect. Prior to that the car had it's MOT done there and no complaints.
    I think they should be ok mechanically but I would never take mine back there for bodywork. You only have to look the cars they have for sale...... Swirl heaven.
  40. #119
    edition's Avatar
    Nov 2007
    1,417
    Coxy, I have always thought the problem might have been sorted through a re-map.
    As you know the Mk4 had to have a map recall at the exact revs you lot are having issues at.
  41. #120
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Quote Originally Posted by Coxylaad View Post
    something definately wrong with mine then. I am stumping for the MAF. will find out tonight.
    it would be physically impossible for me to get 32mpg at the moment, unless i was getting towed lol I did a 25mile round trip at a constant 70mph on the lightest throttle possible and it returned 26mpg.
    The dsg is supposed to have slightly superior fuel economy figures over the manual too.
    Driving along today and i thought.....i know how to piss old coxy off
    Here we are 9.7 miles into a journey at 15.20 doing 37.1 mpg
    And here at 13.3 miles at 15.25 at 60mph doing an 36.2 mpg
    Wonder if that counts as using the phone while driving ?.......
