Page 26 of 26 FirstFirst ... 161920212223242526
Results 1,001 to 1,016 of 1016
  1. #1001
    TQS
    Aug 2005
    Manchester
    267
    Thanks - was wondering if there were any more sympathetic dealers locally??
  3. #1002
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,147
    Sympathetic dealers LMAO!!!.............seriously though, give your local dealer a shout first, there's no reason for them to be obstructive
    E93 335i
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
  4. #1003
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    553
    Pardon me guys n gals, this has been a very popular post and I'm being lazy trawling through it so apologies in advance for this BUT, does this problem also affect an S3 DSG?
    My S3 DSG is suffering low rev hesitation.
    Cheers,
    KKP
    You can take the boy out of Essex but not Essex out of the boy...
  5. #1004
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Sorry but its really only applicable to the 3.2
  6. #1005
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    553
    Cheers Paddy - I'll query it with the dealer when its due in for a service...
  7. #1006
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Audi issued an ECU flash to fix it eventually but it was for the 3.2 V6 only as far as i am aware...sorry mate
  8. #1007
    3.2 DSG
    Im having similar problems to what you describe above.
    when my engine is cool it runs fine, however when its warmed up and I stop at lights or the car is in neutral or park the revs go up to 1500 and then back down.
    ive checked the MAF and this is fine, ive also cleaned out the throttle body. Im thinking that it could be the idle control value. does anyone know whether these can be cleaned out as these are park of the TB.
  9. #1008
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    First you need to get someone with VCDS to down load any fault codes. You could spend a life time chasing the fault round otherwise.
  10. #1009
    GavinM's Avatar
    Nov 2004
    Falkirk
    10
    Quote Originally Posted by paszko View Post
    I had exactly the same behaviour about 2 months ago. Since then, the car's been in the garage three times:
    1) problem diagnosed as the timing chain being stretched, and the angle of the cam adjusters was incorrect, leading to strange firing behaviour. Fix was to replace the chain, and replace 2 cam adjusters
    2) got car back, after a few days, the emission control warning light came on. took to garage, got sensor replaced as the diagnostics unit had identified a fault (it was reading -20 degrees C when it was about +5)
    3) after a day or so, the car was exhibiting the same sort of issues. Exhaust Actuator identified as being in permanent retarded position, so it wasn't working properly. Got that replaced this week (well both inlet and exhaust actuators), and the car's been running fine and idling smoothly at 625rpm.
    Unfortunately, this is a rather pricey thing to get fixed:
    1) cost around 1700
    2) was around 80
    3) was around 750
    My car is 6 years old, is a A3 3.2 V6 DSG S-Line, with 74k miles on the clock. Apart from normal wear/tear/oil changes, this is the first piece of work been done on the engine.
    Any q's - give me a shout.
    A3 3.2 V6 S-Line DSG
  11. #1010
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I think thats dead cheap mate. Mine came to nearly 10k !!
  12. #1011
    edition's Avatar
    Nov 2007
    1,417
    hehehe Not cheap these modern cars are they when they go wrong!
    For Sale :Set of Black Rear carpet Mats P.M. for a Price
  13. #1012
    Apr 2011
    197
    Quote Originally Posted by 3.2 Ju View Post
    Works fine for me Paddy but here's the post:-
    My software is currently 7001
    The tpi number has now changed to 2010289/3 (it also worded gearbox judder poor acceleration when changing gears at high revs, but the update is the same sw version)for those dealers struggling to find the original tpi which has been removed from elsa pro and elsa win
    svm code for the update is 8P01A005
    CD UPDATE DISC 4F0 906 961 N
    I have added this for the member who spoke to me today lol
  14. #1013
    Sep 2010
    24
    Digging up this thread again....
    Just to say I got the update applied through a non-dealer source. If it is of any use to anyone, I have the files off the update disc mentioned earlier in this thread, and more importantly I have them in decoded .bin format (this might not mean much to you but it will to your tuner!).
    Remap next!
  15. #1014
    Sep 2011
    17
    Read whole thread, I will probably avoid buying the V6!
  16. #1015
    Nov 2011
    Is the TPI 2010289/3 update only for A3 3.2s? I have an '04 TT 3.2 DSG which sounds like it could benefit from the new software. My controller number is 022.906.032.DP. Thanks.
  17. #1016
    Jul 2011
    30
    how do you know what the latest version is? I am on 0650
