Results 1 to 19 of 19
    Wai-Fan's Avatar
    Jul 2008
    New York
    522
    Visit Wai-Fan's Instagram Channel
    Axle Stand Points
    Just checking whether these two bits are the places where I should put an axle stand.
    That sticky outey weird shape thing.
    The round rubbery thingy.
    Thanks.
    2006/2008 - 52 Peugeot 206 1.4 LX, Platinum Silver
    2008 - 04 Audi A3 8P1 2.0 TDi (140) Sport, Mauritius Blue
    2013 - 2010 Audi B8 S4, Quartz Grey
    edition's Avatar
    Nov 2007
    1,417
    I'm also wanting to know this! also where do you put the trolley jack?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I wouldn't have thought the rubber bit was the right place. The axle is always the best place but isn't always accessible on modern cars. Not looked on my car though.
    If it's just a quick lift then you can use the normal jacking point for a trolley jack.
    8P2 S3
    Jan 2004
    York
    1,641
    More importantly whats going on with the sill on the top right of the first picture. Looks a bit knacked to me.
    8V S3 Sportback with options on order
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    That's normal, it's the jacking point.
    8P2 S3
    Jan 2004
    York
    1,641
    Is it ?!?!?! I've had 7 Audi's and a host of other VAG motors during my driving years and never seen a sill edge seperating and mangel'd like that ?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Well it is a little mangled but nothing extraordinary. It's just been used a lot I guess lol
    8P2 S3
    Wai-Fan's Avatar
    Jul 2008
    New York
    522
    Yup I didn't notice the sill until I took the pics! Must of been the previous owner!
    Anyways, would it be ok to place axle stands at them points then?
    26,776
    No, wouldnt trust them with stands, stick stands under the big alum rounded bottomed points you can see on front in 1st pic cause its flat on bottom not round & this is safest part as I have done several times & currently am & the car doesnt budge a mm, perfectly safe, but I also have jack on one side where the jacking point is crumpled which also is same on my car so dont worry, just extra safety incase something like a typhoon should come along quickly, lol, anyway as said perfectly safe under those 2 points on front axle, rears are not to simple.
    26,776
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    if you look below the doors on sill where the 'bobbly' protection stuff is, you will see a triangular indent at front and back of the sill and your jack, in the car or a trolley jack, needs to go under that indent
    rs6's, H&R 35mm, lamin-x, vinyl wrapped grill, cupra splitter, black wing mirrors, de-badged, bmc air filter
    slim40's Avatar
    Aug 2009
    Cambs
    38
    Guys, I use a trolley jack sometimes and made a plywood block that fits the slots under the car after bending one of the jacking points under my scooby. Stops the chassis getting knackered. You could try the same for axle stands too...
    cheers
    Si
    S3 8P remapped to 308bhp/395Nm, all the toys, but no buckets
    26,776
    I wouldnt trust plywood on axle stands, thats fairly dangerous mate, sorry but you need a solid flat contact for axle stands, the location I mentioned earlier are the correct places for the fronts on the "AXLE", dont mean to be pushy but we're talking your life if they fail.
    slim40's Avatar
    Aug 2009
    Cambs
    38
    Absolutely, if you're going to do it, they'd have to be made with a lip of some sort to stop them sliding off the stands!
    Safety first... and last!
    PS Decent hardwood ply, not that flakey softwood Chinese kack!
    DaveS3Turbo's Avatar
    Sepang Blue S3
    Oct 2003
    1,062
    Err.
    Don't take this the wrong way, but I put my axel stands under the axel on each corner. The car is going no where, have done this around 15 times where the wishbone goes to the wheel.
    David
    2012 Porsche Cayman R Peridot Green MY12
    2011 Porsche Cayman S Basalt Black MY08
    2010 S3 Sepang Blue MY10
    2009 S3 Imola Yellow MY09
    2007 S3 Solar Orange MY08
    2005 A3 2.0T FSI Quattro S-Line 200Bhp MY06 : Misano Red
    2003 A3 2.0Tdi Sport 140Bhp MY04 : Brilliant Black
    26,776
    Dave, thats the location I am talking about mate, thats the best place to put them & safest, doesnt budge
    gabrialboy's Avatar
    Oct 2009
    JHB South Africa
    46
    So I only discovered this thread after jacking up my S3. After discovering that the manual does NOT indicate a proper placement I inspected the the area away from the pointers on the body kit. The only place that seemed sturdy enough to me was as indicated in the 1st pic, the sill area (that looks crumpled) I was unsure as to where exactly place my scissor jack. Did not bother with the OEM unit so decided to proceed on the sill area.... well the car lifted fine but the sill got squashed... is this a problem? I'll take some pics but can someone please post some pics indicating exactly where the jacking points are for the S3... I don't want to damage the side skirts of the body kit.... but you can also only go in so far otherwise you won't be able to use a jack.... I've seen the trolley jack point with the rubbery/plastic covers but they're quite far inn... jack won't work there... Let's put an end to damaged body kitts and sills for good!
    gabrialboy's Avatar
    Oct 2009
    JHB South Africa
    46
    ...so one can clearly see where the sill got squashed....
    Current Ride:
    2012 Ibis White 3dr S-tronic
    Ex Rides:
    2011 Golf 6 Gti DSG- United Grey
    2011 Honda Civic Type R Championship White
    2008 Ibis White (Sunroof, Bucket Seats)
    2007 Mini Cooper S R56-Dark Silver
    2006 VW Golf 5 GTi- United Grey
    2005 Renault Megane RS 225-Burnt Orange
    Apr 2009
    Florida (previously Liverpool)
    655
    This quote:
    Quote Originally Posted by Staz View Post
    ...leads to this outlook:
    The 'cup' of the trolley jack mangles the seam as shown in the picture if you do that.
    You should use a wooden disc in the 'cup', with a left-right facing "slot" sawn into it, if you're going to lift at the seam like that. That way, the panel seam fits into the 'slot' (just like it fits into the slot in the factory jack) and the disc fits into the 'cup' on the trolley jack.
    Lifting it 'the lazy way' as Staz describes, is what buckles the seam, where the two 'sides' of the cup 'chew' into the panel.
    It's a particularly bad idea in places where they salt roads in winter, because the damage tends to break through the galvanic bond with the zinc plating, and as a result rust can take a hold... RIGHT where you don't need it... at the jacking points.
    by all means lift at the roadside jacking points using a trolley jack, but ONLY with a slotted attachment for your trolley jack... I see SO many cars buggered up in this way that it's made me wonder if I shouldn't just go into business making these things! -The fact that anyone can make their own if they want to, (using only a bit of wood and a crosscut saw) always put me off, but it seems nobody actually wants to...
    Keith
    Keith
