DPMAMD Technik
Page 1 of 2 12 LastLast
Results 1 to 50 of 94
    slick-A3's Avatar
    A3/TDI/S-LINE/BBS LM SPLITTYS
    Jul 2009
    67
    Post Thanks / Like
    Unhappy GOLF/A3 2.0 TDI Starting Problem can anyone help?
    hi,
    my dad has the MK5 GOLF TDI 2.0 140BPH, it is the same engine as my A3 and he is having problems with it starting, it takes alot of turning over and it is lumpy when it starts, it does this when its HOT, it starts better when cold but is still lumpy?
    He has changed the glow plugs, as we where told that it could be that but still no change!
    also had it on the diognostic and it brought up no fault codes, can anyone help?
    cheers
    Tom
    Sep 2006
    Surrey
    1,224
    Post Thanks / Like
    I got the exact same fault. Actually starts better when cold. I've changed quite abit but still no cure. When I remember what I changed, i'll post it
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    slick-A3's Avatar
    Jul 2009
    67
    Post Thanks / Like
    cheers, that would be great.
    Some people suggested it may be a MAFM (mass air flow meter) but they are £109+vat not cheap if we dont know if it is that, and i personally cant see how that would effect it.
    Tom
    Jul 2009
    49
    Post Thanks / Like
    Disconnect (unplug) the engine temperature sensor (RHS rear of block), should then start as normal. Then reconnect sensor.
    Not convenient but cheap and handy if your stuck somewhere.
    slick-A3's Avatar
    Jul 2009
    67
    Post Thanks / Like
    Can i do this when the car is hot or do i have to do it from cold?
    Do i stop the car and reconnect and then start it, or re-connect when it is running?
    will this cure the problem of starting when warm?
    Jul 2009
    49
    Post Thanks / Like
    This is a pit stop fix not a long term solution.
    When my old Golf had this prob (ie not hot starting), I unplugged the sensor's connector, started then plugged straight back in while running.
    Never tried it on a cold engine.
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    Temp sensor and replacement O-ring isn't that expensive, I had to change mine was about £25 all in from a dealer (price from memory).
    Not too bad to change and if you are quick on a cool engine, you can do it without loosing too much coolant.
    Paul
    2005 Black A3 (8P1) S-Line 2.0TDi DSG (Ex-MarriedBlonde). Eibach Pro Springs, Koni FSD shocks and a few bling bits inside. HEX-USB+CAN Vag-Com. Gone but not forgotten - Revo 99 GTi Turbo, too much to list mod wise. - 92 Golf Gti Mark 2 16V.
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    I am thinking about changing my coolant temp sensor as well but am having trouble locating it. Please can you let me know where it is hiding or does anyone have any pictures ?
    thanks
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    There is a coolant pipe arrangement on the right hand end of the block (when viewed from the front of the engine) and the temp sensor is on the rear end of it (end nearest the bulkhead).
    Paul
    slick-A3's Avatar
    Jul 2009
    67
    Post Thanks / Like
    Cheers i will let him know, if this doesnt not cure it what else could it be?
    tdi-man's Avatar
    Jul 2009
    989
    Post Thanks / Like
    torsion timing is out can cause lumpy idle.
    as to the hot start i have same fault can be fixed by getting car remapped to inject diesel when hot and cold. as standard it dosn't inject when hot...
    dantdi's Avatar
    Feb 2008
    kent
    448
    Post Thanks / Like
    I had this on my old 2.0 tdi. i changed the temp sensor but was just the same after.
    slick-A3's Avatar
    Jul 2009
    67
    Post Thanks / Like
    Quote Originally Posted by tdi-man View Post
    Okay, how much did i cost you? and where would be the best place to get i done?
    Volkswagen, or JABBA SPORT=(My local tunning specialist?)
    or is this somthing that can only be done by a dealer?
    cheers
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    I would also be interested to know where this can be done as changed the coolant sensor and has made no difference!
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    373
    Post Thanks / Like
    Mine (2005 2.0 TDI Sport) has always been crisp from cold, but worse when hot. I would say that in the 20,000 miles I've had it it's deteriorated as well, but I have heard enough stories of this nature to believe that all the 2.0 TDI engines are the same. It's really no good!
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    If I took my car to Audi would there be any software or ECU updates available for my 2004 car ?
    I wonder if the hot start problem is just in early A3's or if it is affecting any age A3 ?
    May 2009
    south yorkshire
    162
    Post Thanks / Like
    a remap should cure the problem , i know it did on sister in laws mk5 golf 2.0 tdi
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    I think it the ''ENGINE SPEED SENSOR''
    lowered/half leather trim/leather armrest/led's/mood lighting//red calipers/ lifeshine paint protection/plenty of autoglym/poorboys natty's blue/ch/lh ights
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    If it is the engine speed sensor why is it only effecting the car when it is warm and not from a cold start ?
    Feb 2009
    Macclesfield, Cheshire
    42
    Post Thanks / Like
    I have the same problem and had my speed sensor replaced on friday, and what do you know....failed again today and left me stranded.
    Not goo to have spend £220 onf Friday at Audi to have the problem come back 2 days later
    2004 Audi A3 2.0 FSI Sport, Deep Green Perlescent
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    After ringing around many vw and audi specialists today and being told "we would have to plug it in sir to see what faults there are" I spoke to one specialist who says that he knows exactly what is causing the hot start problem but wasn't prepared to tell me over the phone as he said I could then easily go somewhere else and he doesn't like to give business away.
    Basically he said that if it didn't cure the problem then I wouldn't have to pay, but he is sure that it would and is quite common on these cars. The cost to fix it including the labour is £218 ruffly so I was wondering if anyone that knows how much audi parts are has any ideas what it can be?
    I asked him how he was so sure and he told me that he has worked for audi for 15 years and is a master tech, are they any good lol ?
    I have the car booked in for Tuesday and he has ordered the part ready. I am thinking that it might be an EGR valve, MAF sensor or maybe an IMF ? Any help is appreciated.
    d3mon's Avatar
    Jun 2009
    102
    Post Thanks / Like
    I've heard of this problem before and also recall some kind of 'fix' that had been proposed by someone which basically isolated some component temporarily, while starting occured.
    I wish I could remember the name of it now..
    The most popular 'workaround' advice seems to be to depress the clutch and start without touching the throttle at all.
    Update: What's known as the Hamman/Hammond mod seems to be the solution I saw. Seems cheap but may be complicated/scary to implement.
    Mentioned here: http://forums.tdiclub.com/showthread...=134622&page=3
    '09 A3 2.0 TDI Black Edition 140PS
    Got: Bose, Xenon Plus, LED DRLs
    , FBMFSW, 18" 7 Twin-Spoke 'Titanium' Wheels, Interior Light Pack, Non-Smoker pack, Debadged
    Want sooner:
    S3 pedals, VCDS (VagCom), LaminX front lights
    Maybe later:
    RNS-e (or equivalent), 19" Wheels (as above)
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    Do you think you might be able to remember what the 'fix' was as it would really help and might save me a bit of money ? :-)
    d3mon's Avatar
    Jun 2009
    102
    Post Thanks / Like
    The linky I added to my last post is well worth a read, I'm not much of an engine tech I'm afraid. The final posts on that thread suggest even an old battery might be a/the cause.
    Want sooner:
    Maybe later:
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    That is an interesting read :-) I wonder if it could be my starter motor ? Better try the clutch pedal trick.
    18,284
    Post Thanks / Like
    This is the temp fix by Hammam obviously for certain cars but may also help for 8P's, at your own peril but not exactly hard to do:
    http://forums.tdiclub.com/showpost.p...2&postcount=30
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
  28. #27
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    I worry about doing things like this and would prefer to get to the bottom of the underlying problem lol
  29. #28
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    Have picked my car up from the garage today and guess what.............the car now starts when it is warm I can't believe it. Would anyone like to have a guess what it was ?
  30. #29
    May 2009
    46
    Post Thanks / Like
    Quote Originally Posted by DaveA3-TDI View Post
    do tell!!
    IMF? Crank sensor? Temp sensor? New battery??
    All of the above?
  31. #30
    d3mon's Avatar
    Jun 2009
    102
    Post Thanks / Like
    Engine temp sensor?
    Want sooner:
    Maybe later:
  32. #31
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    Nope none of those, it was the starter motor. The mechanic who defo knows his stuff said he has seen alot of these on this engine throughout the VAG range cause the problem. Wish i hadn't wasted money changing the fuel temp and coolant temp sensors first though lol.
  33. #32
    d3mon's Avatar
    Jun 2009
    102
    Post Thanks / Like
    Yes, the starter motor is metioned in that thread. Was he (the mechanic) more specific or was it just a replacement started motor and nothing more said?
    Want sooner:
    Maybe later:
  34. #33
    Aug 2009
    Stroud
    224
    Post Thanks / Like
    He did try explaining stuff to me but I was in a bit of a hurry when I picked the car up, I think it is to do with not cranking at the right speed.
  35. #34
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    How much is a replacement starter motor just out of interest?
    More problems with my A3, it's becoming a **** to start cold and warm now.. Sometimes it will fire with a 2 seconds and sometimes it won't, but yesterday it was turning over for a good 8 seconds and finally started, who said German motors were bullet proof eh? The car has been scanned recently and nothing showed up on the scan.
    Still think the A3 is the shizzle though!
    Audi A3 S-Line 2.0L TDI 140 Sportback (56)
  36. #35
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,254
    Post Thanks / Like
    I think i have a spare PD140 BKD starter motor laying in my garage if you need one.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    PD140 ported head for sale
    Other car 500+ bhp MK4 Golf R32 turbo.
  37. #36
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    How much fella?
  38. #37
    Post Thanks / Like
    Guys,
    Had same problem hot starts were embarrassing turning 4/5 times before starting.
    Loads of garages suggested Dual MAss Fly Wheel, temp sensors etc however I had a gut feeling that it was the starter motor. Bit the bullet today with a brand new bosh SM and the car now starts perfectly.
    I hope this helps as it was driving me mad and desperate not to waste loads of money.
  39. #38
    ~RS~'s Avatar
    Feb 2009
    1,411
    Post Thanks / Like
    Hey guys thank you very very much for the info in this thread!!! I have had this problem on & off for a while now but it has got pretty embarrassing of late! With a few people looking @ the car trying to turn over as calvinc points out above.
    As this issue is such a problem with A3's maybe this should be a sticky?
    Good s**t guys
  40. #39
    Nov 2010
    Post Thanks / Like
    Hi everyone , this is my first post and I am having the same problem starting my A3 2.0 tdi when warm . It starts first time every time from cold but like a few people have said before once driven for 20 minutes or so it takes 20_30 secs to start . I have the bkd engine and its recently been serviced and I thought this might cure the problem if it was a bunged up air filter or something , but having trawled through a lot of forums I am starting to think a new starter motor may cure the embarrissing problem , its a 2005 2.0 tdi dsg sportback with 84,000 miles on the clock .
    I phoned Audi where it was serviced and told them of the problem and they said they would rather plug it in to the computer for any faults , but when I said that it had just been serviced and no fault codes came up they phoned back and gave me a price for a new starter motor but said they could not guarentee that it would solve the warm start problem , so what is the concensas , should I bite the bullet and gamble on a new starter moter ?
    Any sugestions would be much appreciated , Thanks a lot you guys , I know you know your stuff .
  41. #40
    c_w
    576
    Post Thanks / Like
    It could be the starter but maybe try as above disconnecting the temp sensor? as 20-30seconds sounds VERY long to re-start. I test drove a 54-reg TDI Sportback that suffered this too, it took quite a few turns to start when warm but nowhere near 20-30seconds, more like maybe 3 or 4 seconds instead of the instant 0.5 second it should be.
    Shame "computer says no" AUDI are not much help but it does not surprise me!
  42. #41
    Nov 2010
    Post Thanks / Like
    Thanks for your reply c-w , come to think of it its probably more like 5 or 6 seconds , I got carried away and exaggerated a bit, but because there are no fault codes I really need to try something , thanks again .
  43. #42
    c_w
    576
    Post Thanks / Like
    I would go with people's suggestions/experience then and try a starter (after trying the temp sensor disconnect which is free!). That's the problem with AUDI is that they rely on fault codes, if there are none then they don't know where to start!
  44. #43
    Richy_C's Avatar
    May 2010
    Derbyshire
    451
    Post Thanks / Like
    We had the same problem on my partners mk5 TDI golf, it went in the garage about 4 times until they gave up and swapped the car for a new scirrocco.
  45. #44
    18,284
    Post Thanks / Like
    Starter, as they suffer from heatsoak from the gearbox therefore affecting the solenoid operation, proved this on 2 8P's both of which are mine still in use, the new starter makes an unreal difference.
  46. #45
    Nov 2010
    Post Thanks / Like
    Thanks , im going to book it in with Audi as they quoted me £312.00 all in plus you get a two year warranty on the part . My local indipendent was only twelve quid cheaper so it makes sense to stick with Audi , I will post the results once ive had it fitted so it might some other poor soul with the same problems , thanks again for all of your input .
  47. #46
    18,284
    Post Thanks / Like
    Mate just do it yourself & note the exchange starter is about £130 from my dealer, so save yourself a few hundred as it isnt that hard to do at all tbh & the part is still warrantied for 2 years.
  48. #47
    ~RS~'s Avatar
    Feb 2009
    1,411
    Post Thanks / Like
    Hi NHN, as u know I am having the same issue. How easy is it to DIY the starter: what is required & how long does it take.
    I may have a go at this over the weekend if it's easy enough.
    Hope ur well btw mate, was reading your daughter done you proud at the hospital the other day
  49. #48
    18,284
    Post Thanks / Like
    Easy, just remove your airbox parts which is 10 minutes, then disconnect the connector to the starter, then disconnect the main thick wire with a spanner, use a hex socket to undo the 2 bolts, lift out the back end at an angle then up & out she comes, piece of piss on a bkd 2.0 tdi tbh, make double sure those bolts are done up tight, but dont try to be mr universe and snap them & its gearbox out possibly to replace.
    Yes she did her papa very proud, she's a frigging star mate she really is, she's gonna be a real devil to control I reckon in the next year, she's already moving allot & almost standing, I'm truely shocked.
  50. #49
    ~RS~'s Avatar
    Feb 2009
    1,411
    Post Thanks / Like
    Cheers for that... I lol'd when I read your escapade at the hospital Glad to hear she's coming along well, I told you she would keep ya fit didn't I
  51. #50
    18,284
    Post Thanks / Like
    She's got daddies wickedly evil sense of humour, I did whisper "do papa a favour whilst there" lmfao
