Badger5Chris Nott
Results 1 to 12 of 12
    PTTM's Avatar
    Pedal to the Metal!!!
    Mar 2008
    Tewkesbury
    85
    Bluetooth for Iphone 3GS ramdomly disconnecting???
    Hey all,
    I had my a3 rnse installed with the latest OEM Bluetooth handsfree (module) kit. I linked my new iphone 3GS upto it no problems. However on a regular day to day basis the system whilst driving the car will bong and tell me BT off/disconnected. I will then have to manually reconnect the phone. Why is this? Its sooooo annnoying!!!!
    I will try removing the phone from the cars memory and see what effect that has. Any thoughts?
    Sep 2007
    171
    I am also getting exactly this with a 3GS.
    It was perfectly stable on my old iPhone 3G sigh.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    Could be a setting in the ipod 3g s to disconnect the BT after a certain amount of time during no activity to save battery?
    that's just a thought though...
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    Aug 2009
    Alaska
    I have the same exact problem with my 3GS! I checked the iPhone settings and could not find anything about shutting off bluetooth. Mine connects, then after a minute or two disconnects and then after a minute or two reconnects. Annoying x2!
    Nov 2008
    389
    I think its just a case of subtly different bluetooth chipset on the 3GS. Hopefully iPhone OS 3.1 may help? (Due pretty soon)
    More chance of Apple helping out because as far as I know nobody has ever managed to flash update an Audi module? Maybe dealers can if pushed? - but generally classed as a hardware number revision when all they obviously do is alter the firmware within?
    Always seems a bit silly when things like Fiscon can easily be updated by the end user...
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    323
    Mines started doing this too, has anybody solved it yet?
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
    May 2009
    146
    Quote Originally Posted by wesley View Post
    And me - it's really starting to pi** me off! never happened in my 1st gen IPhone! wHY OH WHY DOES IT DO IT?!!!!
    Nov 2005
    Now is Paris
    19
    Same problem here with my 3GS and 3.1.2 OS
    g.
    A3 2.0TDI S-Tronic Sline '06
    Upsolute Stage 3 / Turbo Dynamics MDX481 Stage 2 Hybrid Turbo/ Milltek downpipe
    108.000 miles so far...
    From Madrid, Spain
    Now in Paris
    27,129
    I assume you've all removed pairing, then re-paired the units as had this on my tocco ages, until removed pairing then re-paired, also silly but try to change the pair code with vagcom on audi BT unit, then re-pair, stupid things can make differences, check to make sure authorisation in the 3GS BT settings is always given, see if remote sim is enabled as mine seemed to be better with this on.
    Mar 2009
    Leicestershire
    100
    I have a HTC Touch HD running Windoze mobile. I have precisely the same problem using the latest Audi bluetooth kit (fitted 1 month ago).
    It may be the bluetooth kit then.
    Nov 2005
    Now is Paris
    19
    I don't think it's the BT car kit. Mine is from 2006 and I have never been this kind of problem with my old Iphone 3G
    g.
    From Madrid, Spain
    Now in Paris
    Aug 2009
    London
    19
    My 3G does this as well, This is also my 3rd iphone 3g that I have used on the kit and it still does it so dont think it is anything do with repairing etc. I think it must be the phone because whe3n it disconnects, i check my iphone and it is dead with just a black screen until it then reconnects with the BT but then it just says searching and takes a minute or two to get signal back again. Very Strange!
    Audi S3 8P3 Sportback S-Tronic, Phantom Black, RNS-E, Bose, Panoramic Sun Roof, Privacy Glass.
