Badger5EM Tuning
Results 1 to 26 of 26
    Sep 2007
    23
    Eggy smell and engine management light
    Hi guys,
    got a a3 3.2 v6 dsg. Engine management light has come on, revs are bouncing around on idle and getting a strong eggy smell from engine bay!
    Any ideas?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    battery ?
    Sep 2007
    23
    Why wud ther b an eggy smell??
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    lack of water in the battery causing it or "The sulphur smell from the exhaust, is actually caused by running the engine/cat convertor slightly lean for long periods and then running under a rich condition (ie going up a hill under heavy load) This is when the sulphur smell (rotten egg) is produced.
    Under relatively lean conditions, the sulphur found in gasoline is converted to sulphur trioxide, then during the rich running condition the sulfur trioxide is converted into hydrogen sulphide (rotten egg smell) within the catalytic converter.
    Audi of America issued a service bulletin Group 24, #92-04 which detailed this problem. They list the cause as : the gasoline sulphur content and the characteristic of catalytic convertor to store sulphur compounds and release them during rich engine running conditions.
    Switching gasoline brands may help. The Oxygen sensor may also need to be replaced to correct a fuel injection mixture problem"
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    or you have a flatulence problem your unaware of ?
    Sep 2007
    23
    Wats that? Thanks 4 ur help btw
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Talking
    Quote Originally Posted by baz1 View Post
    Wats that?
    farting
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I had this last week. Lumpy at tickover but fine once reving. You need to get the fault code but mine was the lambda sensor. About 200 at Audi fitterd and tested.
    Sep 2007
    23
    i'm also getting a petrol smell and a whooshing noise everytime i press the accelerator. Is this safe to drive to the garage tomorrow?
    edition's Avatar
    Nov 2007
    1,417
    The battery is in the boot!
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Mine smelt of petrol at tickover as well....I drove it 20 miles to audi guildford no problem...
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Wink
    Quote Originally Posted by edition View Post
    so you are saying that if you never topped it up with water the smell of sulphur would magically disappear and not enter the cabin ?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Quote Originally Posted by voorhees View Post
    Its not likely as it has a sealed lid to its compartment and is maintanance free anyway. Cant see how this would give him a lumpy tickover either..
    at the end of the day its guess work but can he drive it saftly to a garage........well i wouldnt put my head on the block
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    It's probably a faulty coil pack, causing an overrich situation, causing the cat to spew the fumes
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Quote Originally Posted by paddy View Post
    so okay your right I'm wrong but whats saftly
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Saftly is a special word we use down south when we cant spell the real one
    Sep 2007
    23
    turned out to be faulty front lambda sensors. The front two. The guy at the garage quoted my 400 including fitting!!
    Is it me or is this far too expensive?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Baz
    See my post above....... number 8 !!
    Sep 2007
    23
    Was that 200 quid for both of the front lambdas?
    edition's Avatar
    Nov 2007
    1,417
    they look easy enough to get to......
    How much are they each?
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Sorry, couldn't resist!
    //R
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Rob...your barred
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    That's not very mice. There's no need to be so catty.
    But yeah, I guess I've been a little Photoshop-happy this weekend. I'll give it a rest, for now...
    Rob.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Baz
    My invoice was for one but it was only 74+vat...the rest (149) was "investigation" as they put it...
    Sep 2007
    23
    which audi was that paddy?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    That was for my A3, 3.2 DSG 2004.
    I used Audi Guildford.
    I just checked the invoice and the part was actually 93 but i got 15% discount because the old girl is over 4 years old ie: 79.14p.
    hope that helps...
