EM TuningChris Nott
Results 1 to 21 of 21
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    LED Sidelight wedge bulb
    Has anyone found a suitable LED sidelight that fits in the normal holder, I want to upgrade the sidelights so they match the xenons but don't want the bulb blown lights warning to keep showing.
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    I used a company on ebay - they supplied a blue bulb which lastest ages but they did eventually pop!
    I will try find the link for you - think you need bulb number 501
    Aug 2009
    London/Luton
    ive just ordered a set of these for my sidelights, hopefully they last a bit longer in the a3 then they did in my previous car
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Oct 2008
    Telford
    2,484
    I bougth a set of those exact ones, tried to fit them yesterday. They dont work in my A3, shows the bulb has blown on the DIS. They wont even turn on. When removing them from the headlight one also fell out of the bulb holder so i now have one rolling about inide my headlight housing!
    I'm seriously miffed because now i have to take the bumper off to get the headlight out to fish out the rogue bulb!
    I tried the other in my Lupo though and they look great in that! :-)
    B6 1.8T Avant s line gmbh
    Mar 2009
    Staffordshire
    1,189
    ultraleds sell good quality bulbs - not sure if you'll need a resistor though.
    http://www.ultraleds.co.uk/501194t10...lb-p-1545.html
    http://www.ultraleds.co.uk/ultimate-...te-p-1684.html
    Mar 2009
    Staffordshire
    1,189
    Quote Originally Posted by Lee_R View Post
    you'll need one or two 150 ohm resistors then mate, not sure where you'd wire them up but there must be somewhere you could solder them on the back of the headlight? I'd imagine there's a guide on here somewhere....
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    i have the LED side lights and they work fine, but i am also running them DRL s6 LED off of the side lights so its got enough resistance to work. but regarding the loose bulb in ur headlight. get a wire coat hanger through the H7 bulb socket and try to drag the bulb to the back, there is a small gap at the bottom, it happened to me and thats how i got it out!
    rs6's, H&R 35mm, lamin-x, vinyl wrapped grill, cupra splitter, black wing mirrors, de-badged, bmc air filter
    Aug 2009
    833
    im assuming i can just solder a resistor in parralel on the bulb? 150ohm definitley work?
    Aug 2009
    London/Luton
    i got some 150 ohm resistors from maplins the other day, still yet to try it tho. read that a3/s3 led bulb how to guide
    Aug 2009
    833
    cool cool, ill just steal some from work
    Mar 2009
    Staffordshire
    1,189
    Quote Originally Posted by Nutkin View Post
    I'd imagine so but if 150 doesn't work then I'd guess at 120.
    Are you Nutkin from CCUK?
    Aug 2009
    London/Luton
    Does anybody know where the best place to solder in the resistors for the LED sidelights? or is soldering it to the bulb the only option?
    Mar 2009
    Staffordshire
    1,189
    Quote Originally Posted by fsi2.0 View Post
    I'm not sure but I don't imagine soldering it to the bulb is the best option - you'll likely melt the LED bulb
    Aug 2009
    London/Luton
    Quote Originally Posted by scott1andrews View Post
    your right, couldnt see it lasting long at all. ive just found these on ebay, tempted to try them
    http://cgi.ebay.co.uk/2x-25w-LOAD-RE...d=p3286.c0.m14
    seems quite a few people on the mk5 golf forum are using them with no problems
    Feb 2009
    hampshire - UK
    686
    i think the ones like those get extremly hot! i used used some, similar to that but like a big white block, and there got very very hot. i used 330 Ohm resistors on my interior and number plate light, but i had to use more than one on some of them!
    Gryphon001's Avatar
    Jun 2009
    303
    Quote Originally Posted by gixxer600k4 View Post
    That my friend is a bit of an understatement... lol. I used them inside my hatch to work with the LED number plate lights... recently one blew and I had to replace it. Well after about 6+ months the resistor wasn't gold anymore. It burned off the colour from the casing, came out looking nice and silver. I tried the ones which are wrapped in shrink tubing too. The tubing says it is designed to resist up to 125C... the tubing melted.
    I am going to try to install the small 2W 150 ohm ones with each bulb now... as soon as they arrive from Hong Kong. Isn't eBay great...
    nvc
    Oct 2009
    45
    Quote Originally Posted by Scott View Post
    just had bad experience from the ultraleds,
    bought a few bulbs on the 30th Nov, nothing turned up ( today is 11th Dec) contacted them a few times, just got ignored
    worst shopping experience for many many years. ( I buy 100+ of stuff online every year )
    8utters's Avatar
    Apr 2007
    Littleborough, Lancashire
    24
    ..yup, my experience of customer service from UltraLEDS is crap too, I sent some faulty bulbs back from my TT for refund, they gave me a credit note. Whenever I tried to use the credit note it didn't work, contact eventually just got ignored, won't use them again!
    lake_m's Avatar
    Soon to be S3'd up.
    NE England
    62
    Straight replacement and no resistor required.
    http://www.hids4u.co.uk/501-led-canb...-1-pr-199.html
    Lotus Exige S - Gone :::::::::::::: RS4 Avant - Gone::::::::S3 Black Edition - Gone::::::::::TT RS::::::::::::
    nvc
    Oct 2009
    45
    Quote Originally Posted by 8utters View Post
    exactly, unbelievable they can get away with a credit note,
    I have contacted my credit card company, will get full refund back.
    credit card is always handy when things went wrong
    there is nothing you can do with rogue website, buying on ebay. you can leave a feedback ( ebay is a rogue website as well)
    jamessg1962's Avatar
    Jan 2006
    Newcastle
    115
    These work no need for resistors.
    http://www.ultraleds.co.uk/501194t10...d609feee1394c5
