Hi all,
Following on from my previous post regarding the ECU removal!
I have successfully installed the new stalk. However, after looking at the wiring harness on the steering ECU, I noticed the pin 13 isnt populated. I believe this is where the repair wire need to go?
My car is late 2004 - and from reading other posts confirms my suspicions that I need to run the repair wire.
It did come with the kit, and I have installed it in Pos13 in the Steering ECU harness, but following the instructions that comes in the kit i have no idea where the 'Radiator Tank' connector is!
I have read other posts about this, and someone mentioned removing the wiper cowel to gain access. The instructions dont seem to mention this - but they do refer to workshop manuals for procedures, so I may have missed this step.
If someone could confirm this for me before I take anything else apart that would be great! Ive investigated under the dash (ive removed the lower panel) and cant see anything that fits the description - so im guessing it is under the wiper cowl.
Thanks again in advance, as you guys are always really helpful.
Martin
Martin
