EM TuningBadger5
Results 1 to 7 of 7
    Apr 2009
    Florida (previously Liverpool)
    655
    'Reverse' question: -How do I power an Audi Radio?
    this is the 'other way round' from the other question...
    I have upgraded to an RNS-E, and I want to power up my old Concert II+ radio as a workshop bench radio/CD player etc...
    I've tried just applying power and ground, but it doesn't want to turn on... not even asking for the code. -Is there an adaptor which allows me to do this?
    Keith
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    You might be out of luck. It has a CANBUS network connection and the "on/off" is triggered by the ECU.
    What I don't know is whether the K-Bus connection is just a switched 12v supply that you can just apply power to on the radio or whether its some other sort of signal or voltage trigger that you won't be able to emulate....
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    Apr 2009
    655
    Quote Originally Posted by alfiejts View Post
    I don't think the K-wire is used on the 8P, so I suspect you're right...
    Damn...! -If only someone made that CANbus adaptor thingy in reverse...
    [French Accent]
    Mozzer -Phuqquerrrrrrrr!!!
    [/French Accent]
    (bummed!)
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    I think this is what you're after:
    http://www.connects2.co.uk/c2search....=202&modID=561
    EDIT: Scrub that, that does the opposite.
    8P2 S3
    Apr 2009
    655
    Quote Originally Posted by Staz View Post
    yeah... that's what I was referring to when I mentioned the adaptor which I wanted the reverse of...
    -My fault, -I should've provided a link.
    Oh well... -Anyone want to buy a Double-Din Concert 2+ then? ( it's got Shiny Silver knobs, and everyfink!!!)
    Keef
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Quote Originally Posted by VWAddict View Post
    Keef
    It's definately possible. On some of the RNS-E auctions you can see they've got it running to display the nav screen on the table.
    8P2 S3
    Apr 2009
    655
    ...Knowing my luck, they probably just run a REALLY long multi-conductor cable out into their garage!
