AH FabricationsEM Tuning
Results 1 to 15 of 15
    ~RS~'s Avatar
    Feb 2009
    1,463
    312MM upgrade DIY?
    How hard is it to swap over a set of calipers/ discs & pads from the 2.0 TDi's standard set up to a set from the MK5 GTi?
    I have a set inc pads, discs, calipers and carriers. As the calipers & carriers are already painted red I want to swap everything over. What does this entail though? Does the brake system have to be bleed? Is vagcom required?
    Cheers!
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    You could have got away with just changing your carriers and putting in the GTI Mk5 discs and pads.
    It's fairly easy to chaneg them over though.
    2 bolts on the back of the carrier, screw on the brake disc and undo them.
    There's 2 clips which hold the pipe which goes to the caliper (n shaped)- pull them out with a pliers. One's behind the disc and ones on the arch.
    Undo the bolt located on the pipe (just above the clip on the arch) and the pipe of the old caliper should come off and pull the old caliper off.
    Put the brake disc on with the screw.
    Then wind back the piston on the new caliper, cooper grease the pads and put them in the caliper and put in the holding clip.
    Put the caliper on with the 2 bolts.
    Connect up the pipe the same way you took the other one off but tightening the bolt which connects the pipes.
    Put the 2 clips back on (n shaped ones)
    Bleed the brakes (undo the bleed nipple and put a pipe in a bottle and get someone to pump the brakes)
    The caliper on your 2.0 tdi and mk5 gti are te same - just the brake discs, pads and carriers are diff so you dont have to change the caliper but you my aswell to keep it all red! But you could savea bit of time by not changing it but its your call!
    hth
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    ~RS~'s Avatar
    Feb 2009
    1,463
    Thanks for that Kaz! Much appreciated... Yeah I was aware that the carriers, disc and pads were all that were required (think I seen one of your other posts on the subject as it happens) but as they are red I thought I may as well change all, save me painting the old ones.
    Is there any special tools required (excuse the newb Q's, I usually ket the mechanics deal with this stuff)
    kaz219's Avatar
    Jun 2008
    1,796
    Erm - youll need the torx head set to undo the bolt on the discs (hit a hammer on the disc (middle area where the bolts go) to shock it a bit to undo that bolt otherwise you'll thread it.)
    A socket set.
    A caliper winder (but you could use a g clamp to push it back it - leave the pad in while winding back to avoid damamging the seal)
    may need a long wrech/tourqe wrench as some of the bolts are really tight.
    cooper grease.
    The brake fluid will leak from the disconnected pipe so put the new caliper back on as soon as you can and you'll need some brake fluid to top it up (DOT 4 i use).
    Thats about it!
    Vagcom'd too
    kaz219's Avatar
    Jun 2008
    1,796
    Also need an 11 or 12mm spanner to undo the bolt which conenct the 2 pipe together!
    Vagcom'd too
    ~RS~'s Avatar
    Feb 2009
    1,463
    Much appreciated!
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    If anyone is after a 312mm brake upgrade i have a set for sale that came off my car. The carriers are molded into the calipers with mine though so all one piece.
    http://audi-sport.net/classifieds/sh...ct/3453/cat/12
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    I wish my AMG set up was this simple
    Feb 2007
    1,257
    The only thing simple about your AMG setup is the person fitting them...
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    I'm thinking of doing this mod to my car also. Does anybdy know if the rear GTI calipers and discs are the same as the 2.0TDI? or are they worth cahanging?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    Quote Originally Posted by devonmikeyboy View Post
    As simple as the devon folk then
    Feb 2007
    1,257
    Quote Originally Posted by N8KOW View Post
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    LOL - your funny mike, fcuks knows where you reponse came from? Quattronics are doing my set up, got discs now, buying pads next week then handing over to them. Whens your car gonna be ready? Bigger turbo again?! You'll be doing this = to everything in your way. Where abouts you in devon, I'm from Bristol, so when its up and running I'll drive down and you can show me what the torque eating monster is all about lol
    Feb 2007
    1,257
    I will PM you mate as i don`t want to take this thread off topic.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    Quote Originally Posted by kaz219 View Post
    That is correct as that is what 'Mikey' has done. Kaz have you got any pics of your A3, don't think I've seen any, also what mods you got planned?
    Replied. Cheers Mike.
