Chris NottMonster Motorsport
Results 1 to 24 of 24
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Launch control !
    I have had my A3 for a couple of years and only today i find it has "launch control" what a hoot !! I cant stop smiling. Roll on next traffic light burn up!!
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    Do not abuse the LC! This leads quickly to a broken flywheel!
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Presumably as it is controlled by a DSG program it has safe guards built in ??
    6+1 Gears
    Jun 2009
    Romania
    797
    What safe guards? LC basically let's you rev the engine above 4000(?) RPM than suddenly releases the clutch. It is quite a shock on the flywheel and all internals involved.
    Sure, it is fun though!
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    The manual says "the DSG is equipped with a special LC program to give you optimal acceleration". I assumed that this program stops you exploding the Gearbox.
    If it was going to burst the flywheel would they tell you in detail how to use it in the manual ?? Not trying to be argumentative....just wondering ?
    Jul 2009
    Hampshire
    29
    Rev limiters are there to save the engine also, but I'm sure you wouldnt sit there bouncing off the limiter, time and time again, just because it doesn't say it's bad for the engine in the manual doesn't mean it doesn't shorten the life of the end.
    Smg on m3's and csls also eat gearboxes and pumps aswell as clutches.
    Jul 2009
    Hampshire
    29
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Its ok...I heard you the first time
    There is a difference though. a rev limiter is there to stop you doing something outside the recommended...however the launch control is there as a recommended option within the parameters of the spec....ie it is listed just the same as the windscreen wipers or the horn or the ash tray ...
    Put it this way, the use of the LC is detailed in the manual. It tells you how to set it up and what to do to use it. There is nothing in the manual to say bounce it of the rev limiter in every gear .
    Jul 2009
    cheltenham
    35
    are they on all a3s? as in the LC?
    PregnantNproud's Avatar
    Gears of War
    May 2009
    Near Kent
    301
    I'm a bit jealous. Your a3 must be new? The lc revs the car to a certain rpm then releases the clutch? Cant you do that maunally, and if and when you do, wouldnt that damage the car also?
    "Its not so much that I set out to make an S3, its just I think the S3 is the best body kit for an A3."
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Please don't even think about doing that manually !!!!!
    The LC is standard fit on the 3.2 with DSG. Eat your heart out S3 boys...
    Jul 2009
    cheltenham
    35
    ahh ok im a 2tdi 140 dsg....
    Jul 2009
    Hampshire
    29
    tells you how to do it in the bmw manual also, doesnt mean it doesnt do any damage, as its quite common knowledge in the m3 circle that LC, as fun as it may be, is detrimental to the gearbox and flywheel/clutch assembly.
    maybe the audi version is a very very mild form of LC, and nothing like the BMW, i've never seen the audi one.
    6+1 Gears
    Jun 2009
    Romania
    797
    LC is available on DSG (or automatic gear boxes). On manual you can control the launch with the clutch pedal, but on DSG you cannot control the clutch. You step on the gas, the clutch is engaged ant the car will move. The only way you can rev the engine in order to have a better acceleration without moving the car is trough LC.
    This LC is not activated on all DSGs though. For example I think TDIs don't have it. Mine doesn't. It can be activated but I do not know how. Tuners can do it I think.
    About damaging the gerabox, flywheel and the rest of internals involved, I think it is obvious that when the clutch engages it does it quickly. This thing combined with the hi rev produce quite a shock. in order to reduce this shock, the clutch would have to be engaged slowly but this would ruin the disks and you wont get the acceleration you would expect. Is that simple. There is no free lunch, there is no safe LC, there is no powerful engine that is also economic.
    Oct 2008
    Telford
    2,488
    mine had LC and its an early DSG Tdi, I think anything with a DSG box has it.
    B6 1.8T Avant s line gmbh
    6+1 Gears
    Jun 2009
    Romania
    797
    Not all DSG have the option ACTIVATED. Mine doesn't. I've noticed that most of the cases where the option is not activated are for TDIs. I don't know the criteria for this.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Well how do you know if its activated ?
    6+1 Gears
    Jun 2009
    Romania
    797
    It works! If it isn't activated the car will tend to start moving. You can feel it's trying to move.
    May 2009
    West Yorkshire
    1,628
    Quote Originally Posted by Johnny Bravo View Post
    How would i know if my DSG 2.0L TDI 140 has it? Whats the sequence to enable it? Is it something to do with turning the ESP off?
    If it's not enabled can it be enabled with VAG COM?
    Audi A3 2.0L TDI S-Line Sportback
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    The manual says.....
    ESP off
    Sport selected
    2800rpm on the rev counter and held on the brake....
    Be very careful and if in doubt, check your spec with Audi because you will kill the clutch and the box very quickly if you are holding it on the brake without LC
    My manual says only applies to 3.2 V6 !!!!
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Just like with any car, if your flooring it from a stand still start, you wil put more strain on components and they will eventually break - LC has the same effect.
    Its ok for a once in a while thing but everyday - expect a new flywheel/driveshaft/gearbox soon.
    Its also better to avoid first gear hard starts altogether - i usually get mine rolling in first gear and then boot it in second if i feel the need - no wheelspin, less strain on the components, tyres last longer - less probs with my motor!
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    6+1 Gears
    Jun 2009
    Romania
    797
    Quote Originally Posted by paddy View Post
    ESP off
    Sport selected
    Hold the brake
    2800rpm on the rev counter and release the brake
    If you feel the car that wants to move as soon as you step on the gas, give it up, you don't have the LC activated and you are forcing the box. This will damage the disks quickly.
    May 2009
    West Yorkshire
    1,628
    How do you enable LC though? Can it be done through VAG COM?
    6+1 Gears
    Jun 2009
    Romania
    797
    This I don't know. I know that tuners can do it.
    It would be interesting to know if it can be enabled with a vag-com.
