Volks AutosMonster Motorsport
    Jul 2009
    Hampshire
    29
    What width 18's on A3.
    Hi, what width 18's are best suited for the a3 8p?
    8's or 8.5's?
    after some BBS CH's or S Line ones to replace my 17¨ TT ones.
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    For the A3 8P
    The suggested BBS applications are
    BBS CH 8x18 ET50mm
    BBS CK 8x18 ET44mm
    The 8.5 is available but only in a low offset ET35mm, this will cause the wheel to stick out of the arch too much.
    Please ring if you have any questions
    Philip
    01437 563793
    Jul 2009
    Hampshire
    29
    thanks for the reply. would an 8 on a et35 still stick out a little too far?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,765
    Shouldn't be too bad as you would be losing that half inch (approx 15mm) if they were 8.5
    My BBS CH ET50 are 8.5 wide and sit nicely in the arches
    Oct 2003
    up north...
    767
    with an offset of 35 the narrower wheel may not stick out, but the tyre may still be too far out and catch on the arch under compression as the tyre is wider than the wheel itself.
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Jun 2008
    291
    I run 8.5x19 ET50 MTM's and they fill the arches spot-on
    08 Ibis S3, REVO stg2+, APR HPFP, Milltek TBE, ITG intake, BSH catch can, H&R springs, 19" MTM's, Lamin-x'd
    ???bhp, ???ft/lbs
