JMB RetrofitsChris Nott
Results 1 to 13 of 13
    Mar 2009
    UK
    46
    Check Oil Level.
    Last night on the way home the oil light came on. The light is question is the yellow oil can with "min" next to it. Once home I checked the level and it was low. I popped to my local Halfords and purchased some castrol edge oil. I topped it up with about 3/4 litre of oil. This was allowed to settle and the level was fine.
    I decided to give the car a run and too my surprise the light is still on. I've re-checked the oil and its fine but still the light.... what next?
    The car is a 2008 A3 TDI 170, and it's done 14.5k miles.
    2008 Audi A3
    2.0 TDI 170
    S-Line
    3dr
    Silver / Black Leather
    now with Sat Navigation, Cruise Control and Parking Sensors.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Have you checked again this morning?
    Mar 2009
    UK
    46
    I do a 100 mile per day commute to Birmingham, nearly all motorway. It was checked before I left for work and the level was fine. I'll give it another check at lunch..
    2008 Audi A3
    2.0 TDI 170
    S-Line
    3dr
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    hmm hopefully the oil level should be ok.
    Could be a bad sensor? or just give it another good drive on the motorway again but do check the oil level before doing this!
    last resort could be disconnecting the battery for around 20mins or so reset any fault codes if it reoccurs again but the oil level is fine...it's a trip to audi!
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    Mar 2009
    UK
    46
    Well, just been out to check the level and it's spot on. I'll try the battery thing tonight but it looks as though the warranty will be getting its first use!
    2008 Audi A3
    2.0 TDI 170
    S-Line
    3dr
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    oh ok as long as there is no oil leak then your fine (i would of been really surprised if an 08 audi already had an oil leak!!) yeah the battery thing will clear all the fault codes so it should be able to eliminate the oil light for you..if not then yup 1st use of warranty! lol
    where abouts in birmingham do you work mate? im from birmingham too!
    Mar 2009
    UK
    46
    I'm working at Jaguar Cars, Castle Bromwich at the moment on the new XJ..
    2008 Audi A3
    2.0 TDI 170
    S-Line
    3dr
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    wow! small world my mate works there doing some apprenticeship!
    Mar 2009
    12
    sounds like a sensor fault/try the battery disconnect, another thing the sensor may not read the oil correctly, in the past i added a cheapbrand oil and the sensor failed to reset, i drove til min level on dip then put recommend oil in and the light reset.. my concern is how much oil the audis(vag) burn,i had a oil service/haldex service 3weeks ago, and ive already had to top up the engine oil cos the light come on(have done 2.5k since service).
    Mar 2009
    UK
    46
    Well, I'm pleased to say the light has gone out again.
    I checked the level before my run back to Northampton, the light was on nearly all the way. I pulled of the motorway and decided to give it some stick round the twisties and too my surprise the light went off.
    I'll see how it goes... I've done about 8k miles since owning the car and this is the first top up of oil.
    Time will tell...
    2008 Audi A3
    2.0 TDI 170
    S-Line
    3dr
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    glad to hear mate. yeah sometimes giving the car some stick can sort problems out! i had to do this with my mk5 golf had some emissions fault but noone could locate a problem so i was just told to put a bottle of redex and give it a blast on the motorway! lol problem sorted + was a fun repair ahaha and labour cheap!
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    just keep a close eye on the oil for sometime, not want to be running the beast with no engine oil! better to be safe than sorry, however i think you'l be ok!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Quote Originally Posted by Loneranger View Post
    Blimey..now its blowing bulbs..
