Badger5Chris Nott
Results 1 to 8 of 8
    Apr 2009
    22
    Question Error Code Problem On 2.0l TDI (P2101/P2100)
    My emissions light came on so used my error code reader to find out the problem and knock off the dash light
    2 errors came up on the reader:
    P2101 Generic Throttle Actuator Ctr Motor Circ Low
    P2100 Generic Throttle Actuator Ctr Motor Circ / Open
    can anyone shed any light on these fault codes, im due a service in 600 miles, is there a part i need to order in which can be replaced during the service or is there a fix i can do which doesnt involve buying any parts?
    andy
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Sounds like you've got the dreaded (and familiar) throttle actuator failure...
    There are a number of threads on this if you do a search.
    I paid 203 incl shipping for a new throttle motor last month and fitted it myself. A bit fiddly but only took 20 mins....
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    what happens when this part goes though?
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    The throttle valve closes when you turn the engine off as an extra safety measure to ensure that the engine stops (although turning off the fuel supply usually does the job of that well enough on its own....)
    If you're lucky and it fails fully open, then there is little if any affect.
    If it fails partially closed, then you'll be restrficting the air intake to the engine, affecting performance.
    You might be lucky and be able to tak it off and clean it to stop it sticking, but usually, by the time the error codes come up, the platic cogs of the motor rip their teeth off, so its a full replacement job.
    The fuse usually goes in the fusebox too, so if you still get a persistent error code after replacing the motor, that needs replacing too....
    Apr 2009
    22
    thanks for the info :D
    where abouts is the throttle actuator positioned? havent a clue where to start looking lol
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    right on the front of the engine. you can see it poking out from the engine cover, at the top of a 3-inch rubber pipe that comes up the front of the engine from the intercooler.
    Search for the other threads and there are plenty of photos....
    If you do change it yourself, put a strong plastic bag over the rubber pipe so that you don't drop any bolts down it.
    I took the precaution and it saved me because I couldn't help but drop one of the three allen bolts, as its a fiddly job...
    Apr 2009
    22
    Replaced the throttle body at the weekend and the car is back on top form :D
    cheers for the help guys
    also just to note, i bought the new throttle body from euro car parts, next day delivery 175 all in :D and thats for a brand new pierburg one as well :D
    andy
    Oct 2012
    Leicester (LESTA)
    57
    I've got the same problem on my B6 1.8T convertible. Car feels so slow!! Do I not need to do any vagcom stuff once you put the new throttle body on or is it plug & play?
