JMB RetrofitsAH Fabrications
Results 1 to 21 of 21
    FL1X's Avatar
    Apr 2009
    59
    Advice please is it allready mapped?
    hello
    I have a 55plate A3 2.0TDI engine is in discussion at the moment
    in a attempt to figure out the performance i run some tests with vag com the end results are as follows;
    Torque: 410nm
    Boost: 21.9 PSI (peak)
    can anyone tell me if this is standard for either the 140 or the 170ps engine?
    Im starting to wonder if my car has been remapped previously to my owning it.
    any advice would be muchly appricated if anyone can run chassis/engine numbers let me know as i have that data.
    FL1X
    A4 S-Line 177 TDI S-Tronic
    Aug 2008
    408
    hi m8 can u tell me how u found these figures using ur vagcom?
    cal
    FL1X's Avatar
    Apr 2009
    59
    errrm i had someone else recording the data as i drove but its in engine then just scroll through untill you get rev / torque / torque and the other module was 34 i think its revs boost boost there are two that look the same one is atmosphere and boost the other is requested boost and true boost.
    Hope that helps
    May 2009
    south yorkshire
    628
    log channels 3,8,11
    Aug 2008
    408
    cheers guys
    Jul 2009
    must be remapped to get a figure like that unless its wrong?
    whats your 0-60 time?
    Van is on a tight rope
    FL1X's Avatar
    Apr 2009
    59
    its about 8seconds tops out at 137 on a straight runway...
    which puts it perfectly in line with the 170ps as the 0-60 was recorded in car with a stop watch and the 170ps should do 0-62 in 8 dead
    me wonders....
    i just dont know how to check execpt giving it to audi and getting them to check it for me which i dont fancy doing.
    It doesnt feel remapped ive driven mapped cars and the powers just not there its quick mind you but its not uber quick.
    F
    FL1X's Avatar
    Apr 2009
    59
    Bump
    FL1X's Avatar
    Apr 2009
    59
    update:
    Ive emailed audi but no one seems to be able to help me there either
    any one got a standard 140 or 170 and can run these tests?
    please
    thanks
    FL1X
    10blazin's Avatar
    HYPERDRIVE NEEDED
    Dec 2008
    gorton
    3,272
    no point emailing audi you already bought the car lol ... i bet it would be different if you were buying the car and had been for a test run and wanted to know.....
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    I'm 99% sure they didn't make the 170 when your car was made mate.
    8P2 S3
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Quote Originally Posted by Staz View Post
    Right I was bored ok. But, I checked on Audi's used car configurator for the same spec as yours and every one of the 43 cars I checked was 140 bhp and 320 Nm @ 1750 RPM. May be a fluke, but looks like Staz is correct.
    Also looks like someone has been doing the upgradings on your ECU too; I would imagine 90 Nm is over and above factory tolerancies. Good news for you, but maybe not for your insurance.
    Edit: this is the first 170 I can find - Jul 2006. Even that is only 350 Nm.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    I ordered my previous A3 in July '06 and I remember the 170 was a brand new option on the A3 range. I don't think there are any that aren't single grill either.
    8P2 S3
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Jinx on my edit. Dead leg for you.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Quote Originally Posted by AuldReekie View Post
    lol bummer!
    8P2 S3
    FL1X's Avatar
    Apr 2009
    59
    Hmm thanks for all the replies guys it's kinda disapointing knowing that it's as good as it I'll get without moving into silly monies I suppose I could get Audi to replace the clutch drive chain and all the oils and put it back to standard as they miss sold me the car lol next service paid for and that amount of toruqe cannot be good for a standard clutch!
    Think I will go into the garage on Saturday and see what I can muster
    F
    ps anyone know of a surefire way of checking the ecu map?
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    That torque figure sounds a bit high.
    I've logged block 20 on mine which records engine speed and engine torque amongs other things.
    I then used this from the ross-tech site to give me a figure of 363Nm of torque or 172bhp. Mine is a remapped 140.
    Jon
    Now A3 less......
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    410 NM of torque is more than the 170HP has. I'm sure the engine was remapped.
    I think the 170HP engine has about 370NM and the 140 one has 320NM.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Thats defo remapped mate....
    The 140 wasnt produce till 2006 and it has the straight tailpipes as opposed to the ones that curve down.
    If you look on the sticker in your boot or the sticker in your service manual, it should say 103kw which is 140ps.
    Also, if your engine code is BKD, it will be the 140ps.
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    A2!
    A2!'s Avatar
    Sep 2006
    32
    Stick it on a rolling road. 30ish a run will give you an answer
    Audi A3 8P S line 170 Tdi DSG
    FL1X's Avatar
    Apr 2009
    59
    That's not a bad idea mate I thought rr cost quite some money but if it's that cheap worth it just to get the answer
